The segment joining (7,13) and (-5,-3) is to be divided into four equal parts.determine the coordinates of the points of division.
Determine the coordinates of the point of division
  • 2,878 Answers
Use a piece of graph paper. Easy.
Posted on Nov 20, 2012
SOURCE:
6 divided by 2/3 + 1/2
First add 2/3 (4/6) + 1/2 (3/6) = (7/6) = 1.1666
6 divided by 1.1666 = 5.1431
Oct 03, 2017 | Office Equipment & Supplies
Dividing continuous error. Please help me.
It sounds like your keys are getting stuck. Was anything spilt on the calculator? Is there a way to take it apart and clean it?
Good luck,
Paul
Nov 09, 2015 | Canon KEYCHAIN CALCULATOR REPLACES KC20
How cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
Nov 30, 2014 | Summit Appliances Division Refrigerators
How to calculate decimal to octal
step 1: divide decimal number by 8
step 2: write down the residual of division
step 3: if the result of division if 7 or less, write it to the left of residual you wrote in step 2, and there you go, you;ve got an octal represent. If the result is greater or equal to 8 then:
step 4: divide that result by 8
step 5: write the residual of that division to the left of the last one you wrote
step 6: from tis point everything is the same as from step 3.
Example: calculate octal represent of 123
123 / 8=15 , and residual is 3
15 >= 8, so the next thing you do is:
15 / 8 =1, and residual is 7
so far, we have 73
1<=7, so you write it to the left of 7, and there you go, 173 is octal represent of 123.
Hope this was helpful.
if you want to check your calculations, most calculator software has option to automatically calculate octal represents, i.e.
http://www.statman.info/conversions/octal.html
May 21, 2014 | Computers & Internet
How to put a repeating decimal on a graph
You cannot. There is technique that can be used to locate a fraction on a line segment. It involves the drawing of parallel lines passing through equidistant points drawn on an intersecting line. The procedure is based on Thales' theorem.
Draw a real line (passing through 0 of course) Mark the limits of segment [0,1]
From the point 0 draw a line. Choose an arbitrary length measured by the opening of a compass. Starting from O, mark three equal segments along the second line. From the end of the 3rd segment draw a line that joins that end with the end of the point 1 on the real line.
From each of the two other points on the secant draw segments parallel to the one you just drew.
Here is how it looks on a picture.
If you have another fraction (5/7) draw 7 equal length segments on the second line (secant to the real axis). The parallel line from the 5th point will cut the real axis at the point 5/7
Dec 06, 2013 | The Learning Company Achieve! Math &...
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
PQR is an isosceles triangle with PQ=QR. The side QR is parallel to the y-axis. Calculate the length of PQ, Determine the coordinates of R
Given your limited description, PQ can be any length (though equal to QR) and the point R can be anywhere in the coordinate space. Would you care to provide some additional details? Perhaps a diagram?
Aug 26, 2013 | McGraw Hill Higher Education Calculus and...
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
One divided by zero equal to infinity,why
This is from wikipedia:
When division is explained at the elementary arithmetic level, it is often considered as a description of dividing a set of objects into equal parts. As an example, consider having ten apples, and these apples are to be distributed equally to five people at a table. Each person would receive 08f04ddc176e330c394dee13c81120bb.png = 2 apples. Similarly, if there are 10 apples, and only one person at the table, that person would receive a4e39866af487b126593d0aaaa7d5ab9.png = 10 apples.
So for dividing by zero - what is the number of apples that each person receives when 10 apples are evenly distributed amongst 0 people? Certain words can be pinpointed in the question to highlight the problem. The problem with this question is the "when". There is no way to distribute 10 apples amongst 0 people. In mathematical jargon, a set of 10 items cannot be partitioned into 0 subsets. So ed9f7cc4d52d9a98f859e594a77b31b7.png, at least in elementary arithmetic, is said to be meaningless, or undefined.
Similar problems occur if we have 0 apples and 0 people, but this time the problem is in the phrase "the number". A partition is possible (of a set with 0 elements into 0 parts), but since the partition has 0 parts, vacuously every set in our partition has a given number of elements, be it 0, 2, 5, or 1000. If there are, say, 5 apples and 2 people, the problem is in "evenly distribute". In any integer partition of a 5-set into 2 parts, one of the parts of the partition will have more elements than the other.
In all of the above three cases, ed9f7cc4d52d9a98f859e594a77b31b7.png, 760e263bbe0c0151e575941291b5c190.png and 285df902469bec95c2ddff4ea625c573.png, one is asked to consider an impossible situation before deciding what the answer will be, and that is why the operations are undefined in these cases.
To understand division by zero, we must check it with multiplication: multiply the quotient by the divisor to get the original number. However, no number multiplied by zero will produce a product other than zero. To satisfy division by zero, the quotient must be bigger than all other numbers, i.e., infinity. This connection of division by zero to infinity takes us beyond elementary arithmetic (see below).
A recurring theme even at this elementary stage is that for every undefined arithmetic operation, there is a corresponding question that is not well-defined. "How many apples will each person receive under a fair distribution of ten apples amongst three people?" is a question that is not well-defined because there can be no fair distribution of ten apples amongst three people.
There is another way, however, to explain the division: if we want to find out how many people, who are satisfied with half an apple, can we satisfy by dividing up one apple, we divide 1 by 0.5. The answer is 2. Similarly, if we want to know how many people, who are satisfied with nothing, can we satisfy with 1 apple, we divide 1 by 0. The answer is infinite; we can satisfy infinite people, that are satisfied with nothing, with 1 apple.
Clearly, we cannot extend the operation of division based on the elementary combinatorial considerations that first define division, but must construct new number systems.
[edit]
Oct 08, 2010 | Puzzle Massey Ferguson Tractor
How do i solve puzzle 134 in the bonus section?
134 Land Disputes
1. The feuding parties have demanded that the land be divided into four
identically sized properties. You'll have a much easier time achieving
this if you start all your divisions from the middle of the large chunk
of land.
2. If you find a group of houses or wells together, you know where one of
your proper lines needs to go.
Now you just need to use a little logic to determine where the lines
need to pass through.
3. The division lines for all four properties run through the center of the
map.
You'd do well to try dividing things up further after you've decided how
to allot the four squares in the center of the map.
134 Land Disputes
***XXX
*O***X
*OO*XX
[email protected]@
[email protected]@@[email protected]
[email protected]@@
Thanks and please take a moment to rate as fixya.
Mar 02, 2009 | Nintendo Professor Layton & the Curious...
Open Questions:
AOL MAil Contact NuMbER %%%{1=855=536=5666}#[email protected]@# CUSTOMER This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 16, 2019 | AOL Computers & Internet
Computers & Internet Logo
42 people viewed this question
Ekse
Alun Cox
