Question about HP Officejet 6310 All-In-One InkJet Printer
When i turn on the printer it displays a message''Rest power'' it keeps the same message even when i turn on and off. what shold i do
  • Anonymous Jan 09, 2009
    I have same problem. Called HP customer support at 1 800-474 6836. For $34 they gave me customer support. which said to do the following: Press the #3 button and the pound (#) buttom at the same time for a total of 60 second. If the flashing still continues, this means it is not a software issue. Then you are to press the #6 button and the pound # for sixty sections at the same time. If the flashing continues, which it did for me, they say there is nothing they can do and they then try to sell you an upgraded computer. Good luck, total process on the phone took one hour and twenty minutes. Sorry, this is NOT a joke an it really was not funny.
    Brad
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
The printer keeps saying that there is ink cartridge that needs to be replaced and I have replaced all of them. What do I do next?
The requires to be programed to attain the new accessories installed. Usually the printer would continue functionality once depleted supplies have been replaced. However, power off the entire computer and peripherals, disconnect every link allow to rest for some moments, reconnect the entire setup. Once powered on the new setup should be recognised. For example, the computer would display a message asking to allign the new printers settings. Attemptign to print a sheet should display further instructions of lists that are choices to allign for appropaite appearance of documents and ink impressions suitable. Once chosen an appropiate allignment display for the new setup, that becomes the deafult until suppplies reequire reinstallation.
Jan 28, 2011 | Epson Stylus C88 InkJet Photo Printer
How do I take off the message drum near end when its has been replace
Open the toner cartridge door. Press clear on the console. A message shold display saying "replace drum? press 1 or 2" press the corresponding number to reset the drum counter. This is a very important step when replacing the drum as it actually changes the voltage setting for the dc power regulator. If not performed, and a partially used toner cartridge is in, waste toner can be pulled out of the cartridge and can contaminate the drum unit.
Sep 30, 2010 | Brother MFC-8860DN All-In-One Laser...
Error 0xc18a0001
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold print photo's and the red eye removal buttons then press red eye removal then print photos then red eye removal again. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 21, 2010 | HP Photosmart C6280 Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
How to change a drum unit on Panasonic PD-C262?
It shold be a round cilader that should be the toner which is in a slid out drow which shold be in the may compartment of the printer. You will need to slid it out pull the toner out and place a new one in and firmly slide the draw back in.
May 01, 2009 | Panasonic WORKiO DP-C262 Printer
Printer HP psc 1610 alll in one, the problem keep happening every time I go to print. The printer tells me Paper jam clear and then press ok. I do so and then it keep happening every time I clear even if...
Hi..
open the back door and roll the rollers in backward direction and then disconnect all the cables like usb and power...press and hold down the power button for 30 sec...and then reconnect the cables..and try again...it shold work..otherwise do a comlete reinstallation.
Regards
debroy
Nov 25, 2008 | HP Office Equipment & Supplies
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP 8150N ERROR CODE 79.060E
Power off the printer. Unplug the printer's USB cable for 5 seconds replug turn on the printer. If that fails power off the PC and printer unplug the USB cable at the PC and printer replug and power back on the PC. After PC is fully booted turn the printer back on. If this keeps reoccurring please replace the USB cable and or try different USB ports.
Mar 18, 2008 | Computers & Internet
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Jan 20, 2008 | Dell 924 All-in-One InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
