Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50A60 My husband was given a Toshiba 50A60 from his work, the lenticular screen was shattered when they were putting it in the truck. Any ideas where I could get a replacement, Toshiba doesn't make them any more.
Good morning, I need to clean the inside of the screen, does anyone know how to remove the screen?
Posted on Sep 30, 2009
  • 133 Answers
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Posted on Jan 08, 2009
I have a 50A60 toshiba 50 in rear projection tv I have a green screen no pic but I have sound
Is there a cable or Satellite box hooked up for signal?
How and where is signal connected to the TV?
Dec 13, 2012 | Toshiba 50A60 50" Rear Projection...
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
Lenticular screens...
yes just need to know your size. measure height and width, and i will check the inventory and let you know.also specify if you need both screens lenticular and the outer protective screen
Mar 26, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50a60 cracked screen
i have just experienced the same myself, what you need to do is find a tv the same size, it doesnt have to be the from the same manufacturer, although it helps if you can get the same, as all lenticulars do the same job.
The outer screen is called the Lenticular, and the inner is called the fresnal, depending how bad your lenticular is cracked will determine if your fresnal has gone also, the only real way of knowing is when you take it apart to change it, (Dead Easy).
they are quite close together, but dont be afraid of trying, i have never changed one before, but i did it in about forty minutes and i dont know the first thing about tvs and now it is as new.
to change it, all you have to do is unscrew the front of your tv, from the surrounding screws at the back of it, once you have done this there are four or five small screws that hold the front of it up, take these out and your front will come off complete with lenticular and fresnal.
place it face down on a soft surface, so as that you are looking out of the inside of your screen, and you will see the fresnal.
they are held together with four brackets, one on each side of the screen.
unscrew the brackets, and take the fresnal off, then the lenticular.
put your new lenticular in, then the fresnal on top of that, and then secure it together again by screwing the four brackets back on.
it really is that simple, do not let these TV repairmen, scare you into buying a screen from them and charge you an extortionate amount of money to fit it.
im not sure if plexiglass will work, i was quoted £160+VAT for my screen from Toshiba, so what i did, i went on Ebay and found a full tv that was for spares or repairs, and paid £26 for it, and it is just as it was before.
One thing you must not do when attemting to change it, and that is to be scared of attempting it, because once you have done it, and at a fraction of the cost, you like me will curse the people who make a living out of overcharging people for such an easy job!!!!
Good Luck, and hope this has helped..
Doolb
Aug 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60
This are the part #s for the screens 23430784 fresnel 23430783 lenticuclar . the screen protector just measure the size and go to home depot and they can cut the plexiglass for you. to get the parts go to this link .http://www.vancebaldwin.com/
Jun 24, 2007 | Toshiba 50A60 50" Rear Projection...
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Mar 08, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
310 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
