Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
I read in the manual using cold water could be the problem which I wash alot of my clothes in hot water and then again I heard that a belt could be broken. Please help
  • chelsie_cici Jan 08, 2009
    The washer isnt over 20 years old but yes it will drain and add water but it will not spin when it is time for it to spin i makes a funny sound is it still a drive coupling and if it is what can I do to fix this problem. Thank you so much for you immediate feedback
  • 318 Answers
Unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Posted on Jan 08, 2009
  • Tom Zwiebel
    Tom Zwiebel Jan 09, 2009
    the drive coupling is not the hardest thing to replace, but it does require taking the cabinet off, but no special tools.
    start by removing the control panel screws and hinge it backwards. next remove the 2 brass colored clips that hold the cabinet front,sides and top to the base. with cabinet off, you will see the pump and motor, both held on with clips and screws in motor. then once motor is off, you will find the broken drive coupling. the new one will need to be pressed or hammered on the both shafts and put it all back together.
    it is a very common part to break and should cost about 15-20 bucks.
I went to take clothes out of machine and found were still wet on bottom. A towel was wedge under the agitator and had to be forcefully pulled out. Now machine will do everything but spin.It appears to sound normal. Is this a coupler problem ?
Posted on May 05, 2010
My Kenmore 80 Series washing machine fills with water and drains. It does not agitate or spin. It stared with banging when it would stop spinning. What could be the problem?
Posted on Aug 29, 2009
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer 80 series 110 model not spinning.
http://www.youtube.com/watch?v=WLPGs2UMUJc
This will explain it all.
Posted on Mar 22, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
What is the capacity of my Kenmore 80 series Model 110 washer?
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
2,100 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
