Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
No coffee flows after grinding
My Gaggia Sncrony Compact gridns the coffee but no water/coffee flows.
  • 1 more comment
  • mookid Feb 03, 2009
    similar machhine gaggia synchrony digital.
    Exactly the same symptoms. Dumps freshly ground dry coffee instead of pucks. Works with preground coffee fine.
  • Anonymous Mar 24, 2014
    water flow
  • Anonymous Mar 25, 2014
    water flow
    President:
  • 1,618 Answers
Adjust the grind on the machine.
Posted on Feb 26, 2009
Is drain tray supposed to have water and coffee after each brew?
Yes
That is where the pressure is relieved after brewing. The coarser the grind the more water. Less coffee also will give more water.
Oct 25, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact.No coffee comes out. Coffee grinds then the 3 big clicks, then nothing comes out - grounds get dumped. Bought a new brew group, but same problem.Looked at the book and tried to...
Your machine have scale deposits in a very hard form that is why the water can not run freely.
Here in this link you try descale
http://www.fixya.com/support/r4335301-descaling_espresso_machines_never_use
Try it for 3-4 days repeated, if you dont have any results then you need to desmndle the machine and manualy descale it.
Sep 24, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
What does ventilate mean
Hi
You have to flow water through the steam wand. Push the button for water. Then open the knob on the right to flow water. Once the computer see the the flow meter is spinning again it will clear the light for ventilate. If it doesn't clear the flow meter is not spinning.
Jan 01, 2010 | Gaggia Syncrony Compact Coffee...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
209 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
