Question about Alpine RUE-4185 Remote Control
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
  • 11 Answers
SOURCE: ALPINE-CDA-9854R Radio works but the panel won't light up
the counters on radios with detachable faces go bad forum coronation sum times try a small nail file on them to clean it off
Posted on Dec 15, 2007
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
  • 11 Answers
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
  • 129 Answers
SOURCE: Device Error on ALpin CDA-105 CD reciever
Sorry to say my friend, but the problem is with the Archose. I recently installed a Soundstream unit for a customer of mine, and he had an Archos aswell. The Archose will go in to slave mode, and act as a removeable mass media storage, but that's as far as it will go. Other mass storage units will work fine, you can even use a regular old usb thumb drive, but not the Archose.
Posted on Aug 07, 2009
Alpine CDA-9885 has no sound to rear speakers when playing a CD. Works OK when in tuner mode?? What up??
Are you running your rear speaker through an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amp remote turn on). The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Jul 10, 2012 | Alpine CDA-9855 CD Player
Time set
Try to download its user manual from any one among the folloing links. It will have all details.
If you feel any difficulty in downloading the manual, inform me by Fixya comment, along with your email address. I'll send a copy of the manual to your device by return mail.
Mar 10, 2012 | Alpine CDA-7998 CD Player
I've got a 1988 Dodge Ram and I know nothing about Car Stereos
go down to a electronics shop (future shop or best buy) and they will have a connector that will fit the original plug. Some splicing will be required but its all color coded with the deck
hope this helps
Nov 15, 2009 | Alpine CDA-7840
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from .....good luck
Sep 26, 2009 | Alpine CDA-9883 CD Player
Alpine cda7840 not working
sorry in wrong area. While I am here did u find a solution for this problem? I am having same problem. Please tell me how I can fix this problem. Thanks Bunches
May 10, 2009 | Alpine CDA-7840
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
Alpine cda 9853 cd player
go to fader and turn it down
Dec 22, 2008 | Alpine CDA-9853 CD Player
No sound (Alpine CDA-9826)
Is this a new installation or did it just start happening without anyone changing any wiring? If it is a new installiation make sure you have the remote turn on connected to the remote turn on wire from the radio(blue and white) and not the power antenna wire (blue). The blue wire will turn off when you switch to cd while the blue and white will not.
Aug 12, 2007 | Alpine CDA-9826 CD Player
Alpine CDA-7840
Some 4-Runners have a factory system that uses a separate amplifier to power the rear speakers. In this case you need to activate the amplifier using the blue/white remote output from your Alpine deck. It sounds like the wire that activates the amplifier is currently attached to the deck's blue "power antenna" output, so that the amplifier is only on when the tuner is selected. Disconnect whatever is attached to the blue wire behind the deck, and attach it to the blue/white wire instead. That should solve the problem.
Jun 09, 2007 | Alpine CDA-7840
Televison & Video Logo
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
