Question about HP Compaq Presario 2200 Notebook
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during the outage). There are no lights, no response.
  • melissajoy1 Jan 08, 2009
    i don't know what finally got it to work, but after trying a lot of different things (new outlets, w/ and w/o the battery, reset button, etc.), it just powered up. thanks for your input.
    Novelist:
  • 176 Answers
Check for obvious first like;
Power cycle the strip by turning off and then on the, if that doesn't work try plugging into another power outlet or plug another device or appliance to see if the power outlet is good.
Posted on Jan 08, 2009
    Scholar:
  • 80 Answers
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
Me harddrive is not on anymore, i left it on last night?
There was probably a power outage and you didn't notice it because you were asleep. The Computer's hard drive does not turn on by itself after a power outage.
Aug 02, 2011 | Computers & Internet
After a power outage, my wii will not turn on
You can try a new AC adapter.If that does not work,it will need to be repaired by a Nintendo authorized center.(I used to work at one).If you do by a new one PLEASE buy Nintendo brand.The "off" brands usually end up in some kind of problem down the road.
Good luck and agme on!
Jul 12, 2010 | Nintendo Wii Console
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
Re: Kenmore Plasmaire air conditioner; suddenly stopped working during night. Motor will initially turn on but no air coming through, then will stop
Most likely you have a bad fan,did you have a storm or lighting strike or power drop / outage .
These type of things can cause trouble with a weak electrical part - not know the age of the Unit - you claim it happen in the middle of the night - if the fan Humms and cut outit could be a cap. that helps you fan start - but the fan is damaged if it tryed to start time and time again . Call service if the unit is worth it .
Jul 17, 2009 | Heating & Cooling
Presario 2200 won't turn on after local power outage
Hi Mellisa,
If there isn't any lights on the laptop when it is plugged into the mains supply there is a power problem.
Check the surge protector, has got a reset button?
Plug a lamp into this surge board, if the lamp lights up when the board is connected to the mains then the surge board is OK.
Next check the laptop's power adapter with a multimeter, the voltage reading should be as per the label on the adapter. If the voltage is less than the voltage on the label, then it is faulty and needs to be replaced.
Borrow another adapter to connect to your laptop to see if it powers up or take it to your friendly computer shop to test it.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
Ups troubles
What is happening here is you are transferring load to battery during a power outage but on return of Line Power the UPS is not smoothly transferring back to Normal mode. As a result you are basically turning off your computer. Two options... shut down your computer orderly during an outage or buy a new UPS.
DD
Dynamic Power Solutions LLC
Aug 20, 2008 | Computers & Internet
HP Compaq Presario 2200 Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
