Question about IBM ThinkPad 600X Notebook
Laptop is not responding
I was working on my laptop when it suddenly went blank - am unable to reset it using the power button. It is totally unresponsive.
Perhaps the motherboard is damaged? If the motherboard is damaged does that mean that all the data cannot be recovered?
    Novelist:
  • 176 Answers
Check your AC adaptor and make sure the're securely connected to each end - to the power outlet, strip or to the laptop jack. If its on a power strip try power cycling the strip by turning off and on. Try using another known good power outlet or if not try pluging in another known good device to see if it powers up. Take out battery and just plug in the ac power
If you plug it in to another good outlet and still you dont see any power lights ( green light, blue lights, etc. ), fan or hd boot
Posted on Jan 08, 2009
  • Ed Deguzman
    Ed Deguzman Jan 08, 2009
    power lights ( green light, blue lights, etc. ), fan or hd boot and nothing at all its a good indication that it maybe the motherboard that got damaged
  • IBM Master
  • 787 Answers
1) Try holding down the power button for 5 secs. Let go and try to turn it on again. This is a signal that bypasses the OS and tells the motheboard to power down. This helps if the computer is actually still running but with no display.
2) If that does not work, unplug the computer, remove the battery and leave it at for 1 min. Replace the battery, plug it in and try to turn it on again. Corrupt data in RAM can cause problems like yours, this clears out the RAM so you start fresh.
If the above did not help it might be your motherboard. A bad motherboard does not usually damage your data. You can remove the hard drive and put it in a portable hard drive enclosure (about $30), the enclose plugs into a USB slot in a working computer and shows up as another hard drive.
Check to make sure your power is ok, I ran into a situation where the power bar was accidentally turned off and then the battery ran down.
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
I have a Toshiba Satellite L305-S5968 and all of sudden it went blank and will not do anything. It's pluged up and the lights on so it works I turn power on a blank screen comes on that says enter password...
To use external display, Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons
also try to go to enter password 3 times. and note given error code.
use this website to try make passcode online by type notted code
https://bios-pw.org
Dec 25, 2017 | Toshiba Satellite A60-S1561 Notebook
I hace Acer aspire 4520. Suddenly the screen went blank. I tried to start the laptop but never starts. The power is available, battery is working and power button is illumination. Please advise what to do?
try to re-seating the memory card(s) located on back, clean it if necessary. If it has two cards, try one to another probably one of them is out of order
Apr 09, 2010 | Acer Aspire 4520-5803 Laptop
We went to use our Toshiba L305D laptop. All lights are lit, but nothing shows on screen. Hold in power button to restart and computer sounds like it's rebooting. Screen is totally blank.
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
Jun 25, 2009 | Toshiba Satellite L305D-S5904 Laptop
My HP pavilion dv2713TU laptop does not start, blank screen.
usko land me dal kar chuus fhir randi baja sale banh ke loade,chut age se chut chatio
Mar 14, 2009 | HP Pavilion dv6000z Notebook
Toshiba satellie A135-S4467 screen went blank
Sounds like a bad motherboard if the system just failed and now you can get nothing to happen. One way to check this is to take a monitor from a desktop and plug it into your computer and power on your computer and see if anything happens if nothing happens then replace your motherboard
Feb 16, 2009 | Toshiba Satellite A135-S4467 Notebook
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
My zen suddenly went blank!
Your device lockup isn't uncommon, and in most cases is easy to fix. You need a small paperclip or straight pin to reset the device. When you reset, be sure to hold it in and wait for the blue light to turn off. Once you power the unit back on, it will rebuild and should operate as normal.
Dec 25, 2008 | Creative Labs Zen Digital Media Player
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
IBM ThinkPad 600X Notebook Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
