Question about ASUS P4S8X-MX Motherboard
Restarting i put a nvidia geforce fx5200 ag vga card in to my agp slot..after i turn on my computer is load and restating..i cant install drivers also...some time its showing a blue screen.........?????
  • 416 Answers
May be the card is not properly inserted in the slot. make sure it's set properly, if it's not the case swich back to the onboard VGA & chk the setting in bios for AGP adaptor & see if it's enabled.
Posted on Jan 08, 2009
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
VGA Driver
just try download your VGA driver @
Jan 15, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Nvidia Geforce FX5200 128mb DDR AGP 8x
Hi, since you mentioned you installed an MSI card & it worked well. I can assume you changed the bios & to boot to the AGP rather than the Integrated 3D video. This is good. Notice the message you got from Nvivia. It could not locate any compatible drivers. This can indacates 1 of 4 reasons.
1. The 5200 was not completely incerted into the AGP slot.
2. The AGP slot is dirty & needs cleaned.
3. Nvidia software was installed but previouse graphics software was not removed (un-installed) before the installation of the nvidia software.
4.The card is bad.
Suggest you download the latest driver software from Nvidia.
Jun 17, 2008 | EliteGroup L7VMM2 Motherboard
GeForce FX 5500-picture flickers
assuming you have set your agp slot in the cmos settings to the primary graphics controller and already had the agp graphics slot driver installed for the motherboard, try using a driver from the nvidia web site if you are having trouble with the driver that came on the cd. Use the VGA onboard graphics if you have any or fit your old card and click on the link below for XP Drivers If you still have problems then you will have to try an ATI graphics card as it just may not be compatable with your make of motherboard
May 08, 2007 | XFX GeForce FX 5200 Graphic Card
ASUS P4S8X-MX Motherboard Logo
114 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
