Question about Dell Dimension 2400 PC Desktop
Unmountable boot volume
I was given a sony vaio by my sister when u turn it on it asks if i would like to start normally last known safe mode safe networking etc. no matter what mode i try to run windows in it directs me to page that says unmountable boot volume the stop error number is 0x000000ED (0x86D839E0,0x000009c,0x0000000,0x00000000 what steps to you recommend i tale next to correct this problem? if have the same problem with my pc desktop...i need help please...i just bought this computer....my sister was saying it was beacause the lights were going on and off during the 2008 snow storm they had in louisiana...i live in opelousas....help me please..
contact me at francoisemodi@yahoo.com
    Novelist:
  • 166 Answers
Also you can do the steps to get to the recovery console and type CHKDSK /R and it will run the disk checker program to fix what files it can. This has helped me fix numerous disks. It does not work 100% all the time, but hey 90% isn't too shabby. While it runs it will start counting up % completed, however it may jump backwards a few times. Do not get alarmed this is the computers way of trying to go back and fix corrupted files.
If you get it back running, make a backup of your files. What happened is the worst thing that can happen for hard drives and that is power interuption during a write operation. When that happens files get corrupted. Sometimes hard drives will prematurely fail because of this.
Posted on Mar 10, 2009
    President:
  • 948 Answers
Put your Windows XP installation disk in the drive and boot from the cd. When your options come up, choose Recovery Console. You will then arrive at a command prompt. Type FIXMBR
This will run a utility to attempt to fix your master boot record. This is not a difficult problem to solve, if you are not comfortable doing it with help from FixYa perhaps a tech savvy friend can do it for you. It does happen sometimes from a power outage. You can avoid it by using a surge suppressor with battery back-up, they are well under $100 and last several years.
Posted on Jan 08, 2009
Ok my Sony vaio Model #VGN-NR120E keeps restarting on windows error recovery. I try starting in save mode,safe mode with networking, save mode with command prompt, last known good configuration...
HI dmanhd97,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Sony VAIO VGN-NR120E/S Notebook
My computer froze during shut down, so I turned it off using the power button. When I start it up It gives me the options of starting normally, Last known good configuration, safe mode safe mode with...
Try go into BIOS by hitting the DEL key or F1 or F2 as you start and go to save Cmos config. then reboot.
The other approach is Last known Good config is the best. This can be brought up after presing power button then by tapping F8 till screen apears.. Select Last known Good Config
Nov 08, 2009 | Sony VAIO VGC-RA840G PC Desktop
Your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders. Choose last known configuration to reverse to the most recent setting that...
Choose safe mode and see if you can get into it. If you can then go into system restore and choose the last date that you remember the computer working properly.
At this point the computer will restore the computer back to the earliest date that it was working properly.
Once you do this the computer will reboot and it should go back into windows normally and work just fine. If for some reason it doesn't then windows is corrupted and you'll need to wipe out the hard drive and restore the computer back to factory defaults.
Aug 21, 2009 | Sony VAIO PCV-V210P PC Desktop
WHAT TO DO IF MY SONY VAIO WON'T START?
Hi there.
Choose "LAST KNOWN GOOD CONFIGURATION" if it still won't boot up try "SAFE MODE" and perform a system restore and take the computer back a week or so.
Good luck and thanks for using FixYa!!
May 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony vaio not loading windows
reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Nov 28, 2008 | Sony VAIO VGN-FJ270/B Notebook
Windows will not start up
choose start windows in Safe mode, if it starts then everything will look big, don't worry about that for now. Then go to Start>accessories>system Tools>system restore and choose a date when you know that everything was working normally, when it has finished restoring the computer will restart. If asked choose start windows normally.
I hope this helps
Nov 25, 2008 | Sony VAIO V2M (VGCV2M) PC Desktop
Problem with windows
what, bootleg? the only operating system you can download is Linux.
Try to restre to last known good point (sometimes it says (safe mode, safe mode with network, etc) select that (last known good point) from the list)
Oct 17, 2008 | Sony VAIO VGN-N130G/W Notebook
Will not start up normally (freezes )
it sounds like the operating system has gone corupt so have you got a disc to reinstall windows and all the drivers!if you have i would format the harddrive and reinstall the copy of windows
Oct 30, 2007 | Sony VAIO PCG-K25 Notebook
Dell Dimension 2400 PC Desktop Logo
439 people viewed this question
Alun Cox
