Question about KitchenAid KSM50PR Professional Series Stand Mixer
Kitchenaid ksm50pob no stir speed all other speeds seem ok
The stir speed doesnt work all others seem ok.
    President:
  • 2,976 Answers
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Posted on Jan 08, 2009
KitchenAid Speeds are offset
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
Oct 04, 2017 | KitchenAid KSM150PS Artisan Series Stand...
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
I have just purchased an ice cream freezer for my mixer. It is an older model and does not have a "stir speed" delineated. What is the equivalent of stir speed on the older models? -- 1 or 2?
On models with the "STIR" speed, the RPM (Rounds Per Minute) is 60.
Set your mixer speed to "1" or "2" and do the following:
60 seconds. In your case, the correct STIR speed is 60.
Jul 29, 2011 | KitchenAid KSM50PR Professional Series...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KSM50PR Professional Series Stand Mixer Logo
469 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
