Question edited for a lot more clarity.
Question moved from Misc to model category.
Replace the internal Li-Po battery, but try a reset first.
https://www.google.com/search?q=sandisk+sansa+c240+battery+replacement
If your Sansa player is freezing, not charging or not turning on, the first thing to try is a reset of the unit. This will normally clear any temporary condition that may cause the player to freeze or not shut off completely, it's a bit like when your PC crashes and you need to re-start it to clear the error.
Dec 28, 2020
Sansa Clip Won't Charge - iFixit
iFixit
https://www.ifixit.com > Answers > View > Sansa+Clip...
Feb 15, 2021 - I found an older Sansa Clip which will power on when connected to a USB charger or to the computer, but it won't boot up or hold a charge.
1 answer · 1 vote: Hi, Sounds as though the battery has failed and needs to be replaced. I couldn't find a battery replacement guide for a Sansa Clip but here's a video ...
How to replace dead battery in Sansa Clip mp3 player?
Oct 1, 2010
Why is my clip say tranferring and not charging
Jan 16, 2017
Where can I find a new battery? - Sansa Clip Plus
Mar 27, 2017
My MP3 player won't turn on once I remove the charger.
Aug 3, 2015
More results from www.ifixit.com
Sansa Clip Battery is not charging - SanDisk Forums
sandisk.com
https://forums.sandisk.com > sansa-clip-battery-is-not-...
Jun 4, 2008 - You can try to charge the device first, to make troubleshooting easier. Unplug the device, then select Settings, then USB Mode, then MSC. Now ...
SANSA CLIP ZIP NOT TURNING ON, NOT CHARGING
Feb 27, 2013
Sansa clip won't charge - SanDisk Forums
Jan 4, 2010
SanDisk Sansa Clip+ doesn't charge, doesn't turns on or ...
Nov 2, 2016
Sansa Clip Zip battery won't charge, goes straight to song ...
Nov 28, 2014
More results from forums.sandisk.com
