How do I get the goop out of the pump?
In response to your answer to my question.
  • Washing Mach... Master
  • 8,220 Answers
What i do is get the make and model number and look up the diagrams on the machine using repair clinic or appliance parts pros.
copy and paste this stuff and check it out:
Get parts:
http://www.repairclinic.com/
http://www.pcappliancerepair.com/
additional good reading:
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
For Sublime appliance repair advice, simply written:
http://sites.google.com/site/sublimeappliancerepair/Home
Posted on Jan 08, 2009
Soap dispenser stopped pumping.
Dry soap or goop stuck in the pump or line.
Jul 19, 2015 | Delta B4310LF-SS-SDISP Foundations Core-B...
Long story short after running fuel below E and fueling at station idle went rough then motor quit will start w flud and run a few minutes even afterchangng filter as well as draining tank
Its possible you gummed up the pump, or cooked it.
There may be goop in the strainer before the pump from the bottom of the tank, and the pump may also have overheated since the gas in the tank acts as both a coolant and a lube.
Feb 13, 2013 | 1988 Ford Mustang
No heat, over heating
Not all new thermostats are actually working thermostats.It may require a second one.However,if the fan does not work it will be hard to tell.Is there a fan belt running to it?The goop that was added to it could actually plug up the the rad coils or rods and make it extremely hard to cool itself.It needs to be flushed.
Jan 22, 2012 | 1996 Subaru Legacy
Water Pump Gasket needs replacement
So ... whats the problem? You unbolt the pump, clean the surfact, apply the new gasket with goop on it and reinstall the bolts. Do you have a question about that?
Apr 05, 2011 | Plumbing
We bought 2 different models Jacuzzi commodes this past spring and the clip that holds the filler hose on the inside of the commode keeps coming off the tall cylinder thing that that you put it on and then...
Sorry to read about your problem, I hope this helps you out.
i would goto ace hardware or home depot, and buy plumbers goop, in a purple tube..
glue the little clips on,
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Home
Our ceramic cooktop is unstuck from the metal base. how can I glue together
try a adhesive called goop, works very well on glass/metal. Home Depot and ace carry it
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
Dec 31, 2010 | Microwave Ovens
The handle came off the glass door. It looks as if glue was used to secure it. How should I reattach it? What kind of glue works for a glass door on a toaster oven?
get goop glue from home depot
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 20, 2010 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Inlet Valve leaking
I would try PLUMBER'S GOOP (hardware store) on the copper pipe. Remove it and put a liberal amount of goop on the end about a quarter inch back from the tip -- insert and smooth the goop around the connection -- let it cure for 24 hours -- turn water back on.
Charlie
Aug 22, 2009 | Home
Have a Maytag mah4000aww washer and the "brush" that's around the opening of the tub (inside the rubber area) has some brown "goop" in the bristles. This goop is now coming off and getting the the...
This felt seal must be replaced. The brown goop is the adhesive.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 25, 2009 | Washing Machines
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
