Remote for dvp 3150 won't work
It will powere on the dvp player but I can't select which track on the dvd player and it won't fast forward or rewind.
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
are you using the original remote or a universal remote? if a universal remote, then you might have the wrong code in the remote. try another code. or dont you have the code list for the remote?
thanks
tom
Posted on Jan 08, 2009
Remote for philips model dvp 3050v/37 won't work
Remove old batteries and clean battery terminals with rubbing alcohol, allow seveal minutes to dry and replace the batteries with new ones.
Mar 07, 2012 | Televison & Video
Cannot fast forward with remote
The solution given above works. But just be aware that the remote "Idalia ZM" is talking about that you press enter + 1 on is your television remote. Fast forward, rewind and skip (both directions) worked after doing this. Thank you Idalia ZM!
Jan 07, 2012 | Samsung DVDC500 Player
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
Model c500. How do I change region?
Found this on the web some time ago. Samsung C500 DVD player. Use the following steps to make this player region free;
1. Start the DVD with no disc and use the remote;
2. Click the Repeat (not the Repeat A/B) button located far left of the remote.
3. Click the Fast Rewind button <<
4. Click the Next Chapter button >>'
5. Click the Fast Forward button >>
6. Click the Prev Chapter button '<<
7. Click the Play button >
8. Once the grid selections appear, use the arrow buttons to select/highlight "9" for region free. Make sure to select "save and exit" as shown below to screen on your television. The player will shut-off automatically. Restart and play with any DVDs.
Hope this works!
Jul 21, 2010 | Samsung Televison & Video
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Aug 18, 2009 | Televison & Video
My remote control cannot work on rewind, fast forward or comerical skip. The DVD screen display SET 1.
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
May 16, 2009 | Panasonic DMRES15 DVD Recorder
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
