Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire washer shuts off in the middle of the cycle
It is not a specific time in the cycle it just shuts off intermitently. If we reset the circut break it starts again but nothing else on the circut is having issues. We have tried again to flip the break but now that no longer works.
  • 28 more comments
  • lender685 Jan 08, 2009
    How do I get the goop out of the pump or check if there is any?
    there is water in the tub.
    there is water in there now but it has stopped when there was not water in it. There is no read out display. It is a Frigidaire FWX833AS2 8 cycle heavy duty washer.
    is there anyway to check certain areas without calling in a servcie person?
    its an old dial that turns with the cycle, i'm assuming its on a timer.
    what is the easiest way to get the front panel off?
    there is no lock light on the machine
    thanks
    it has shut off at different points. We were able to get it going a couple of times by throwing the breaker but that no longer works.
    i'm having trouble getting the front panel off.
    took out the screws but front wont come off.
    no, no odd noises.
    sorry..what is the masher :(
    Not a front load washer....top load washer with timer dial.
    got the front off. There seems to be a pump on the left hand side. Two black hoses going into it and two wires? How do I clean it out?
    no, once it shuts down it doesn't go throug the cycle at all. When it runs it runs normally but shuts down at different points in the cycle.
    i'll give that a try....how can I post this in the correct category or do I have to pay again?
    nothing works...drum will turn.
    pushed the switch down manually but nothing happened.
    haven't tried the Frigidaire techs yet.
    does the front need to be close for the unit to work?
    i don't think its a motor issue.
    yes. Jumped it with a paper clip, plugged it back in but nothing happened. Changed the dial to a different setting but nothing.
    got an extension cord and plugged it in to a different socket. It's running now. Waiting to see if dies again.
    Thanks...I'll keep you posted.
    Thanks.
    thanks for your assistance.
    Thanks for you help :)
    Genius:
  • 1,239 Answers
Hi
Take the panel off right under the round door(3 screws) there is a white plug looking like thing(like a gas cap) take that out(water will run out so have a bucket or towels or something) you will see all the muk muk around this plug clean it off and put back in.
Posted on Jan 08, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 08, 2009
    and be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
  • ABHISHEK.C
    It is a good possibility that the solenoid for the cold water has gone bad. Since the Cold and the hot are in the same bracket assembly, you will need to change both at once. A Sears parts department is a good source for a replacement. They will need your machine make, model and perhaps serial number to locate the appropriate replacement shutoff valve. It is always a good idea to take the old part with you since the person at the parts research desk may know less about what yu need than you do. Help them out with the old part as an example if you can. This usually helps to prevent return trips for the same repair part because the new one just won't fit where the original was.
    I do not know your level of expertise, so just in case you are not versed in such things, the shutoff valve assembly is the part that the hot and cold hoses attach to on the washing machine.
    Before removing, be sure to turn off the water valve feeding the hose. If might even be advisable to turn the machine on to bleed off the pressure in a fill cycle or you will make a mess when you unscrew the hoses.
    ALSO: be extremely careful not to let the electrical circuits come onto contact with the water at all!
    Safety first! It is hard to enjoy the repair of your washer if you should accidentally electrocute yourself in the process! BE CAREFUL!
    I hope this helps.
    Sergeant:
    Novelist:
  • 326 Answers
Thanks for keeping us updated and let us also know further what happens.
as it could be a timer problem or the motor or the power cord still the conclusion is yet to be decided.check out this properly and reply.also if the problem gets solved please reply.
thank u for using fixya.
thanks.
    Sergeant:
  • 378 Answers
Check out and reply if it dies.if runs for a long time it indicates that old cord was getting short somewhere in the middle. thanks.
    Sergeant:
    Scholar:
  • 199 Answers
Cycle Not Advancing or Timer Stalling Symptoms Update...One root cause of washer stalling in cycle (timer not advancing) on horizontal axis washers is electrical noise generated primarily by the timer contacts opening and closing which can interfere with proper operation of the speed control board. At times, depending on ambient environmental conditions, this electrical noise can cause the motor controller board to receive corrupt signals and remain on 'stand by condition' resulting in the cycle not advancing. By manually advancing the timer to the next step in the cycle or by turning the washer's power off and on, the electrical noise is discharged and the washer will perform until electrical noise may happen to interfere once again.
To resolve this issue, three jumpers have been added to the current motor controller board to reduce electrical noise levels around the microprocessor. Testing has proven this change to the board significantly reduces occurrence of control lock-up. The newist motor controller board assembly is Part Number 134149220.
also check out this options
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • 679 Answers
There is some problem with the control board of your  Front Load Washer check them using a multimeter.
Thanks for using FixYa.
  • 3,037 Answers
Hi lender
If you open up the front door of the washer, should should be able to find a drain plug/filter beneath the door inside the machine. This collects all of the junk that is piling up and if this stuff becomes too great, the machine may start performing as you suggest. Clean this out and clean out the drain pipe and everything in between and you should have the machine back to normal.
bestdarngood
  • 318 Answers
Sounds like you have 2 possible problems. 1 could be as easy as the outlet going to the unit may be weak and not always making a good connection so the unit shuts off. try it in another outlet or even use an extension cord that is heavy enough to run the washer. usually a good outdoor type orange cord will work.
if that doesnt work then you may be having troubles with the control board. it could have a weak connection or a bad transformer causing the power to shut the unit off.
when the unit shuts off, and you were able to get it to run again, was it at the same place in the cycle or did you have to start a new cycle to get it to run?
  • 6 more comments
  • Tom Zwiebel
    Tom Zwiebel Jan 08, 2009
    i think the reason you are getting the wrong info is you posted this under a front load washer heading.
    sorry but i just checked and you have a top load washer and that has totally different problems.
    what i would guess now is that you are having problems with the lid lock and switch assembly. they are very well known for failing and when the switch gets weak it wont let the unit run. try to push a pencil or something in the hole in the top where the lid strike goes. hold it down and try to run the unit thru a spin cycle. you may not be able to gt it to run if the switch is completely bad now.
    i would just go out and get a new switch and lock assembly and try that. i would bet you find thats what is wrong.
    part number 134101800 about 50 bucks.
  • Tom Zwiebel
    after you take the 2 screws out of the bottom of your front panel, then pull the panel down and then out at the bottom. it has a kind of "keyhole" clip that will hold the front panel to the side panels. kind of hard to see but look between the front and sides and you can see them.
  • Tom Zwiebel
    i dont think you can re-post without paying again, but now that i know what you are working on i think we can get you fixed up.
    by the way dont worry about cleaning out the pump it wont be need as i think your lid switch is the problem.
  • Tom Zwiebel
    how good are you with working with electricity? if you are confident that you wont get shocked then try this... your lid switch has 2 tan wires then you can jumper those 2 wires and that should make the unit think the lid is closed.
    by jumper i mean to connect them together and that will connect the circuit that has failed in your lid switch. you need to unplug the unit then remove the wires from the switch, then put a jumper wire in the terminals to connect the 2 wires. then plug the unit back in and try it again. if it runs after that, then replace the lid switch.
  • Tom Zwiebel
    p.s. i do frigidaire warranty and am pretty sure whats wrong here. do not do the jumper trick unless you are confident that you will be safe. i do it when i am fixing them, but i am trained and know what not to touch. ie any bare wires.... just dont do the wire jumper if you are not sure.
  • Tom Zwiebel
    no your unit will run with the front panel off. did you try the jumper yet??
  • Tom Zwiebel
    well then i would check your washer outlet for power. make sure that you still have power by plugging in a light or something else to be sure the breaker hasnt failed. then if thats ok, you may have a timer problem. not much more you can do yourself after that.
    i really would think its the lid switch but you did what you could to check that.
  • Tom Zwiebel
    sometimes its the easy things we overlook. i would still think you could have a bad lid switch and that could cause the circuit breaker to trip, after enough trips the breakers can fail and not reset.
    so now you need to do another post for.. how do i tell if my breaker is bad? LOL just kidding.
    keep watching to see if the new outlet trips and shuts off, if so then i would change the lid switch.
    President:
  • 1,952 Answers
This is probably a completely computer controlled unit... not old fashion timer that rotates during the cycle, right? ... If spin is fine I guess it narrows out the motor then... but this brings in the "master" control as one possible suspect, and the motor control is still in the equation as well.
The door lock mechanism should also be fine, as it allows spin, and does lock and unlock freely as it seems.
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 08, 2009
    Any noises emitted before it goes off, that you find different from the normal function?
    Once you advance the timer it goes through the cycle quickly filling and draining but the wash motor never engages.
    that be the fuse to check. if you are good at controlboard refurbishing solder in a new fuse if it's open.
    Most likely a motor going bad or something causing a drag on the motor,
    could be something in the blower wheel, drum rollers dragging
    1. Check the power:
    Advance the timer knob to the drain increment. If the drain pump does
    not run, check household safety circuit. If the drain pump runs go to
    step 2.
    Done, drain pump is running.
    2. Check for Motor Movement:
    Turn the water off to the washer. Remove electrical power from the
    washer and remove the back panel. Remove the motor drive belt.
    Reconnect electrical power and set the timer to the start of the
    Regular wash cycle and pull the knob out. If motor does not rotate,
    check for a poor connection in the timer line switch or door lock
    switch. If good, and motor does not run go to step 3.
    Done, motor is running when the timer is set to the Heavy Wash position of the Regular was cycle only.
    3. Measure Voltages:
    Remove the six pin plug from the speed control unit. Measure the
    voltage between pins 5 and 6 of the harness. If the meter reads 0 check
    the connection in the timer line switch or door lock. If the meter
    reads 120 Vac go to step 4.
    Done, meter reads 120 Vac.
    4. Set the timer to the Heavy Wash position of the Regular wash cycle.
    Remove the ten pin plug from the speed control unit. Measure the
    voltage between pins 1, 2, 6 and 10 of the ten pin plug to pin 5 of the
    6 pin plug on the harness. The voltage at pins 2, 6 and 10 should read
    120 Vac and 0 Vac at pin 1.
    Done, but the result is different. Pins 1 and 10 showed 120 Vac but
    pins 2 and 6 showed 0 Vac. There is no cable at pin 2 of the ten pin
    If not, check timer contacts 1C to 1B, 5C to 5B, and 7C to 7B for
    closed contacts, and 3C to 3B for open contacts. If the voltage readins
    are correct, go to step 5.
    Not done, because of the different result on previous step.
    Why is the ten pin plug harness different than the technical spec?
    5 Measure Resistances:
    Check the fuse on the speed control board. If the fuse is open, replace the speed control board. If good, go to step 6.
    Not done, but I assume it is good because the motor is running.
    6. Remove the 6 pin plug from the speed control unit. Measure the
    resistance between pins 1 and 2, 2 and 3, and 3 and 1 of the speed
    control unit. If the meter reads other than 3 Meg ohms + 10%, replace
    7. Remove electrical power from the washer. With an ohmmeter check the
    resistance between pins 1 and 2, 2 and 3, and 3 and 1 of the six pin
    plug on the harness. If the meter reads other than 2.6 ohms + 7 %,
    replace the motor
  • 594 Answers
You may have a short in the washer causing the machine to run and shut off to prevent any other damage to the unit. You will need to get a professional out there and have them run a diagnostic test on the machine to figure out where the short is in the system. If you keep trying to run the unit you may damage the unit more than what is already damaged.
  • Cameron Viseth
    Cameron Viseth Jan 08, 2009
    im sorry there is not i am usually about to get you a diagnostic diagram but for your model one does not exsist for me to get to you. what i did get was the a link to your owners manual,wiring diagram,operation manual,and parts list. but no diagnostic diagram.
    http://www.frigidaire.com/support/Result...
    i hope i have been some help to you. Thank you for choosing fixya.
    Please do not forget to comment and rate about your experience today.
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
it sounds like you have a electrical problem. can i have the brand and model number of the washer, please.
thanks
tom
  • Thomas Jan 08, 2009
    when you try and use the washer what works and what doesnt? will anything turn on? does the drum inside turn free or is it stuck?
    have you tried contacting the technicians at frigidaire? if not i think that is your best plan. they can help you alot more than we can. to me it still sounds like an electrical issue but they will be able to help you even more.
    Sergeant:
  • 311 Answers
Is there water in the tub? or no water
  • 17 more comments
  • Thomas Malailua
    Thomas Malailua Jan 08, 2009
    if water ,then could be shuting down because wont drain,so would need to remove frount panel,pump on the right.have a bucket to drain water.[you can loosen pump from washer and lift]take pump apart and clean...............if no water ,could also stop,but should show error code,but may not.that would be cleaning the water valve screens
  • Thomas Malailua
    the pump is the white or tan pice with two hoses and two wires,on the right after the frount panel is removed
  • Thomas Malailua
    if somtimes with water and somtimes with out that dose confuse things abit,but a blocked pump can confuse the control board
  • Thomas Malailua
    dose the door lock lite stay on when it stops
  • Thomas Malailua
    the screws are at the bottem of the panel rt/lt sides
  • Thomas Malailua
    there is a door switch/lock that also must keep the curcit closed for the washer to continue working.lock lite going off might indcate its bad
  • Thomas Malailua
    test
  • Thomas Malailua
    tip the masher back abit
  • Thomas Malailua
    washer !!!!!!!,pull down and out
  • Thomas Malailua
    sorry about the masher
  • Thomas Malailua
    you can use a screw driver to pry a little,wont be much though
  • Thomas Malailua
    im sorry your post is showing a frount load washer.sooooooo lid swith it what controls run
  • Thomas Malailua
    also i like what another poster said about house wall receptcal is it worn
  • Thomas Malailua
    no the frount dose not need tobe closed to work
  • Thomas Malailua
    the frigadire lid switches are tricky.thers more than two wires
  • Thomas Malailua
    cool that where we need to always say start from the begining[power]
  • Thomas Malailua
    again everthing in the post sugjests frount loader .picture and wording.just goes to show a picture dose paint a 1000 words the worng words.i hope your all fixed. God bless ,tom
  • Thomas Malailua
    if its the lid switch the one for top loaders is part#134101800 theres one one ebay for 22$ plus shipping
  • Thomas Malailua
    i have done over 15,000 in home service calls and would replace more lid switches for a dead washer than any other part .but thats if i had power at the house
  • Frigidaire Master
  • 8,220 Answers
Get the goop out of the pump
  • Dan Webster
    Dan Webster Jan 08, 2009
    Probably an underwire or simular object partially blocking the pump/dump valve operation.Check pump for objects.
  • Dan Webster
    Get a putty knife and remove the front paneltake pump apart. Clean out ****. that is all
I have a top load frigidaire affinity washer. Lately it seems to shut off mid cycle or sometimes run through the wash cycle while skipping some steps. Is there a way to reset the computer?
Hey, I understand that you are having some problems with your Frigidaire Top Load Washer. From what you have described it sounds like there could be something going on with the control board. Before contacting a service provider, I would recommend resetting the washer by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 10, 2015 | Frigidaire Washing Machines
My Frigidaire washer, GLTF2940FS1, has stopped in the middle of a cycle. I can eventually get it to start again, but it stops within a minute or two. Is there anything I can try before calling for a r
Hey friend, thanks for your inquiry!
I see that your Frigidaire washer, GLTF2940FS1, is stopping multiple times within the cycle. It sounds like a potential issue with your control panel of door latch assembly. You should perform a reset on your appliance by unplugging or flipping the household circuit breaker for ten minutes.
If that does not help correct the issue I would advise you to seek technical assistance from a professional for proper diagnosis and repair. This would help avoid any unnecessary part purchases. Best of luck! -Matt
Oct 08, 2014 | Washing Machines
I HAVE A FRIGIDAIRE AFFINTY LAFW7000LWO WHEN DOOR IS SHUT THE DOOR SENSOR STARTS
Good Afternoon Friend,
I understand that the door sensor goes off on your Frigidaire Affinity washer, model# LAFW7000LW0, when the door is shut. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Dr is flashing. The error code is E41. How do I correct the error code. Door is closed. Started flashing in the middle of cycle.
Hello, welcome to FixYa. I understand you have a Frigidaire washer with an error code E41, correct ? Can you reply and include the complete model number ? This will let me speak specifically about your washer instead of generalizing...which can be fine, but specifics are always better. I'll watch for your reply and go from there. Thank you. Regards, Macmarkus :)
Sep 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Middle of cycle and won't start, just hums
You have a drain problem check the hose going to the pump.I bet u find a sock or such in it.
Nov 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
Jun 14, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
