Question about LG DLE2512W Electric Dryer
My LG dryer gets stuck on six minutes. What can I do?
Model # DLE2512W. We tried cleaning the humidity stips but it did not work. Please help if you can. Thank you.
  • LG Master
  • 8,220 Answers
Easy fix. Wipe the capacitance sensing metal stripes located right below the inside of the filter. Make sure the 2 metal stipes are very clean. This measures the capacitance of the clothes and constantly records differences till the clothes are dry.if **** is on these then you would have failure. Porvavor.
Posted on Jan 08, 2009
Dryer stops at 6 minutes on sensor cycle
If you have chosen the manual mode and the dryer works well , then the fault can be with the sensor. need to check if there is false reading or if the control board has a issue.
Try to clean the unit and reset for a trial.
Oct 18, 2011 | LG DLE2512W Electric Dryer
My Lg DLE2512W dryer works but the lights dont come on
Unfortunatley this will probably mean a new board. The lights power is fed thru the board and the chances of everyone of those little buggers blowing at the same time is very, very, small. Sorry, hope this can help.
Jan 25, 2010 | LG DLE2512W Electric Dryer
LG DLE2512W Dryer says chech filter, starts, heats and turns but makes loud noise. Maybe something stuck? A sock?
Drying drum is not on its host. Lay down the dryer and then bolt it after aligning it.
Oct 07, 2009 | LG DLE2512W Electric Dryer
Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Dec 22, 2008 | LG DLE2512W Electric Dryer
My LG Dryer timer gets stuck on 6 minutes everytime
Look inside the drum on the right side of the filter. You will see two metal strips, thee are humidity sensors. Wipe them down with soap and water. It worked for me. The info came from LG tech support.
Nov 12, 2008 | LG DLE2512W Electric Dryer
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
LG DLE2512W Electric Dryer Logo
192 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
