Question about Whirlpool Duet GHW9150P Front Load Washer
Control Lock light stays on
The front door was opened when the machine was operating and the control lock light stayed lit. I've tried opening and shutting the door, disconnected the power, held the pause stop button but nothing seems to work any suggestions
  • Anonymous Mar 18, 2014
    We have WFW9150WW front loader washer. When we press the power on and start button, the add a garment light stays on. We hit power button again and everything locks up. The door will not unlock and all the lights stay lit up.
  • 640 Answers
Defective door switch,,replace
Posted on Jan 09, 2009
After self cleaning oven door remains shut won't open, no access by push buttons which are now not lit
oven will stay locked till oven cools off to room temp , this is a safety feature (no burnt hands) and no front panel controls should be able to override this feature , if it still wont open some models have a "release" button that must be pressed on top back control panel after a clean cycle is run to signal to operator that oven is ready to wiped out , but that's a feature that id only seen on commercial ovens
Sep 25, 2015 | Ovens
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a control locked alarm on a whirlpool duet washer??
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control off is on, how can I fix it?
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The stays on control locked and I cannot turn it off
usually you can push and hold the button next to the lock light. it will have a picture of a lock next to it. if you push and hold it for 5 seconds it should unlock the control board.
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The control lock light is on
there is a button on the far rt of the face of the machine...you hold that button down. the button is called end of cycle signal.
ann
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal De
