Question about Linksys Wireless-G WRT54G Router
My linksys router won't allo me to connect to the internet.
I have three laptops and one desktop. Recently I have been getting a lot f problems with my linksys router connection. I have had it for about three or four years now and have called linksys support. They fix it everytime and then a couple weeks later, same problem. When I connect directly to my att motem my desktop will work. But I need the router so that the laptops may connect to the internet wirelessly. Today I had this problem again and called three times. They fixed it and three hours later it happened again, no connection. Now they are telling me my router (WRT54G ver 2) is old and if replaced with a new linksys roter, I will have no more connection issues. I don't know if this is true and I just want to have a router that works so I don't have to sit on hold every other week trying to solve the same issue over and over again. Please help. New router or can this be solved? And are the newer models reliable?
Thank you.
  • 928 Answers
Well to be honest. The reason you keep having the problem is because your router resets itself every few hours. If your routers firmware was already updated by LInskys support and the same thing happens then you will indeed need a new router. Newer models and even the one that you have are all reliable the only problem in your case is most likely wear and tear. You have had it for a few years now hence most likely its degraded to a point that it resets itself which causes your problems so yes i would suggest you get a new one. YOu can get the latest WRT54G V8
Posted on Jan 08, 2009
My router is Linksys Wireless-G 2.4Ghz' My desktop is link with a cble to my router. It works fine, but the momment a laptop connects to the router, the internet connection is usually gone. Worse if two or...
Two possibilities. Either the ip number for the laptop is the same as the hard wired LAN connection (if so change one of the ip numbers to a different one unless using DHCP) or the wireless is failing in the router.
Feb 16, 2011 | Linksys Computers & Internet
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
My linksys router won't allow me to connect to the internet.
You probley should get a new one. The new ones should have a better conecsion and more settings.
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Limited connectivity
check your ip adreses
it is range of router
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wireless Network working on laptop, lost internet on desktop.
If you disconnect the desktop from the modem, were you able to get an Internet connection in your laptop?
In order to get Internet connectivity on your desktop at the same time with the laptop, then the desktop needs to be connected to the router. It should be connected to one of the Ethernet ports at the back of the router. Since, your desktop doesn't have an Ethernet port, then you need to connect a USB to Ethernet adapter to your desktop. Then from that adapter, you will connect to it an Ethernet cable going to the router.
You may check the following models:
Linksys USB200M
Linksys USB100TX
Belkin Gigabit USB 2.0 Network Adapter(F5D5055)
D-Link DUB-E100
There are other brands that offer USB to Ethernet adapters that you can check.
Hope this helps!
Nov 22, 2008 | Linksys Wireless-G Broadband Router
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
I can get online with one laptop, not with the other one
What is the operating system of your computer that is not working?
Aug 19, 2008 | Linksys Wireless-G WRT54G Router
Connection problem
What's the model # of the Linksys router?
Can you describe to me your physical connections from the modem going into the router? What ethernet port from the modem goes into the router's ports, etc.?
Apr 06, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys Wireless-G WRT54G Router Logo
122 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
