Question about Gateway GTW-P42M303 42 in. Plasma Television
Gateway grw-p42m203 I was watching my tv and turned it off and now it wont turn back on??????? the remote doesnt work or the button on the front of the tv. NEED HELP????????
  • Anonymous Feb 14, 2009
    Gateway GTW-P42M203 Audio is ok but it is showing no signal and the video on the screen is all garbage.
  • 3 Answers
See for symptons, cause and fix...
Posted on Jan 10, 2009
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
Tv wont turn on by pushing power bottom on
pull out the plug for 3 minutes and then back in again. maybe that works!
Dec 03, 2011 | Televison & Video
My sony trinitron tv wont turn on. it blinks 4 times on standby. what do i do
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Aug 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Remote control and buttons on top of tv wont work!
you unplugged the front panel with the buttons on it and the remote reciever
you have to slide the chassis out
reach in to the front and replug the front panel to the plug from the main board
then slide all boards back in place
Aug 26, 2009 | Sony KV-35V42 35" TV
GTW-P42M203 shut off and will not stay on
Chances are there are cracked solder on one of the boards. This is a common problem with Gateways. If you're handy with soldering then this is an easy fix.
Jun 30, 2009 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Gateway GTW-P42M303 42 in. Plasma Television Logo
482 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
