Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Dvd's won't play
Since i bought my monitor i cannot play dvd's on my computer.troubleshooter tells me to change resolution, but still no good. is it because i only have an analogue cable. the idiot i bought it from hasn't a clue. please help...
    Genius:
  • 2,985 Answers
There is to me no connection between the three problems. If the monitor behave with normal computer wor there is nothing wrong with the reolution. Analogue/HDMI cable makes no difference if fact although I must asdmoti to be getting on a bit [well into my fourth decade] when I play may monitor [which has both] by flicking the switch - I casn see no appreciable difference. Coming back to the change the reolution. If you put a driver in for the monitor - delete it let Windows sort for its self see what happens and come back
Posted on May 31, 2007
SOURCE:
My 933sn has this stupid problem. when playing old games at 800x600 half the screen gets streched vertically. i play all the other games at 1360x768 but some like age of empires 2 or counter strike,...
Try changing the resolution your TV is putting out; it may not be in full screen, but at least everything won't be stretched! 800x600 has a different ratio than 1360x768
May 06, 2011 | Samsung 933SN Monitor
Pls how can i play my DVD player with my hp 1730 lcd monitor i'v tried connecting through VGA but its saying ''out of range'' what do i do? Help!
The resolution (most likely the 1080p HD) is too high for your monitor
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00477225&lang=en&cc=us&taskId=&prodSeriesId=346693&prodTypeId=382087
. You will need to access the dvd player's menu somehow and reduce the resolution to one that is supported: ideally it should be the 480p SD one that your player surely supports. The exact procedure is in the manual.
Apr 13, 2011 | HP 1730 LCD Monitor
I get the Monitor is in power save mode and won’t boot normally. It will boot in VGA mode but then goes haywire when you try to change the screen resolution. I’ve also gotten a blue screen saying a problem...
Usually this problem happens when the video card is sending a signal to the monitor that the monitor does not recognize. (Kind of like me telling you how to fix this problem in a language I dreamed up myself.) The monitor will work on a different computer, because that computer has a video card "talking" to the monitor in a language it understands. So the solution is a different monitor that has a resolution setting your computer can talk to. Possibly you can borrow one, change the resolution of the card, and put your own back in. You can plug in and unplug monitors while the computer is on with no problem, to test.
Nov 01, 2017 | Dell M992 Monitor
16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Nov 08, 2009 | Dell Computers & Internet
Just bought an Acer AL2216WBD flat panel monitor. Have an old Dell computer; "Jewel Quest" game loaded. When I plugged in the new monitor, tried to play the game. Good sound but no picture. Only "input...
the resolution is incorrect for that new monitor , it does not support it, attach the old monitor reduce the display resolution and then hook in the new monitor, up the resolution until it fails again and do nothing it will reset to the last good display resolution and you can leave it there.
hope this helps
Mar 06, 2009 | Acer X193W LCD Monitor
Monitor Problem
1. Try using a different media player like k-lite windows media player classic or GOM player.
2. Is the lcd set at it's native resolution ? Set it to native resolution.
3. Has the driver for the lcd been installed and does it show up properly in device manager ? Install the lcd driver if applicable.
4. What are your system's specs, especially graphic card ?
5. Has the latest graphic card drivers been installed ? Install latest drivers.
6. Does using VGA or DVI make any difference ?
7. You would've probably already checked windows media player settings.
Hopefully some of these will solve the problem.
Dec 22, 2008 | Samsung T190 19" Widescreen LCD Monitor
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
Nov 26, 2017 | Princeton Digital VL1916 19" LCD Monitor
DVD playing
Right click on the desktop anywhere there is clear space.
Select Display properties and then select the last tab at the top of the window that pops up.
You should see the slider there to set the resoloution, and to the right is the colour depth.
Nov 17, 2007 | BenQ FP731 17" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Widescreen reset
Go to the control panel and click display and reset it the way you want it. You may have to do this everytime you play your game.
Apr 25, 2017 | 3G Technology GEM GL-822A/B 17" Flat Panel...
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
