Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem with continuing washing cycle
I need some help with my washing machine. I can turn the machine on and get the machine ready for a wash cycle. The machine fills with water but before it's ready to begin it doesn't. I have to go over and open the door and drop it so that it will continue sometimes only once but lately I have to open and close it several times. Any suggestions...the machine is not more than 2 years old.
  • Anonymous Oct 27, 2008
    I have the same problem. It finally started when I slammed the door down, but lately, it's been taking over 150 slams to get it to start. And now, I've slammed the door or hit the machine more time than that, and it still won't start. Any ideas? There doesn't seem to be a switch on the door.
    Sergeant:
  • 236 Answers
Possible door interlock switch.
Posted on Jun 01, 2007
SOURCE:
MW511 washing machine continuously restarting washing cycle.
isnt there an error code your not telling us about
Jan 21, 2018 | Washing Machines
Samsung WA13M7 washing machine working but water continues to fill up in machine. So we need to manually turn off water. Then we turn it back on for rinse cycle. To spin I need to turn machine off and...
Could be a water valve is permanently open inside the machine.
this will need expert attention. but first try: Unplug the machine and leave it off for a while then (with help) rock the machine a few times before plugging in.
Jan 28, 2014 | Samsung Washing Machines
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Washing machine continually running water
the water valve that connects the inlet hoses to the machine is stuck open and needs to be replaced if the water continues to run after you have turned the machine off
Apr 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
1 year old Frigidaire front loading washing machine will only
Check the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Pay particular attention to the hot water side. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid and the valve assy will need replaced. I'll attach a photo for reference. Hope this helped and best wishes.
Oct 07, 2009 | Washing Machines
Washer will not start/continue with cycle
check if the water pump is not blocked in any way preventing the water from emptying properly as the machine wont continue until the water sensor tell the machine that its ready for the next cycle the pump may not be doing its job preventing the next cycle to take place eric
Jan 15, 2018 | Kenmore 24872 Top Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
78 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
