I have a lexmark 6180 that will not scan
The all in one will copy, but it does not seem to be communicating with my laptop. I have down loaded the new driver software for Vista, but it didn't seem to fix it.
  • Stereomaster Jan 08, 2009
    The problem here is that the drivers for upgrading the Lexmarks to Vista, are only partial drivers. I have the same exact problem. Honestly, the only solution is to buy a new printer that is compatible with Vista straight out of the box.
  • 3 Answers
I have the same exact problem. The problem here is if you read the Lexmark website carefully, these drivers are only partial drivers, and you can not scan with these drivers installed. The website tells you to use windows fax and cameras for this purpose. The best solution is what I did, return that Lexmark, and buy another brand that is compatible with Vista straight out of the box. The 6100 series of Lexmark is an older series that was made for XP. I hope this is helpful. I know it's frustrating, but it's not our fault that Bill Gates made sure nothing is compatible with Vista, it's not just printers but cameras, camcorders, you name it.
Posted on Jan 08, 2009
My Lexmark S301 keeps indicating that it cannot retrieve applications list for scanning
Try using the Lexmark Printer Home software to scan. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
Oct 26, 2012 | Lexmark Impact S301 Wireless All-in-one...
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
Won't scan
Hi. The problem can be caused by a firewall blocking the communication. Try to configure your firewall to allow all lexmark communications to go through. Also, check if scan software FineReader Sprint is still working fine. Otherwise, you have reinstall the software. Hope this helps.
Mar 15, 2010 | Lexmark X4270 All-In-One InkJet Printer
My lexmark 2600 , don't scan, or copy. I changed
make sure that all driver are loaded properly so that the pc will be able to understand or can be able to communicate with the printer
Oct 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
114 people viewed this question
jasbo
jasbo
