Question about Whirlpool Duet GHW9150P Front Load Washer
The stays on control locked and I cannot turn it off
Whilpoor Duet
My 4 year old daughter forcefully opened the front door when it was operating. Now the control locked light is on and I cannot shut it off even when I unplug and put it back it still remain the same. I need help.
  • 318 Answers
Usually you can push and hold the button next to the lock light. it will have a picture of a lock next to it. if you push and hold it for 5 seconds it should unlock the control board.
Posted on Jan 08, 2009
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool gold door falls open during cycle
You can probably get away with getting just hinges for the door if it is not bent also check the latch if it doesn't look broken the just go for the hinges.
Jan 11, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The door is locked but the control lock is not on
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 19, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
