I am having a problem...i installed alcohol 120% and when i try to mount it....i cannot...the mount on device option is not highlighted and cannot be clicked... what did i do wrong? or what do i need to do?
    Scholar:
  • 111 Answers
For mounting your legally backed up programs I recommend Daemon Tools link provided;
It is far simpler and has a better compatibility with images then alchohol
Just set the number of devices
Select a Empty Device
Navigate to the location of your image
Double Click it
Enjoy
Dont forget to rate my response ;)
Blazamane
Posted on Jan 08, 2009
Arma 2
You could use Alcohol 120 to mount or burn the image. To burn just use the image burning wizard. It's on the first page when you open the program. To mount an image, first locate your image using the wizard, its on the front page again. It's creativly called (Image Finder) This will find all the images on your machine. Right click on the image you want and select--Mount on device-- Hope this helps.
BTW Alcohol 120 is trialware..so eventually you have to buy it.
Jul 30, 2009 | Logitech 250 Headset
Tip
How to remove a rogue Alcohol SCSCIVAX drive from your PC.
This SCSIVAX drive is a virtual CDROM device that is usually created by Alcohol. Normally, the uninstallation of Alcohol will remove this device but its not always guaranteed.
There are two possible solutions to this :
1. If you still your copy of Alcohol, then reinstall it. Once installed, you should then be able to find a setting in Alcohol (under Options->Virtual Drive menu I think) & set the number of virtual drives created on startup to zero. This will make the SCSIVAX drive disappear. Once gone, you can uninstall Alcohol again.
2. The other option, if you are comfortable with registry editing, is this :
Run regedit.exe, then in the left pane, navigate to :
Hkey_Local_MachineSystemCurrentControlSetServices
Right click on the Service branch & select 'Export'. This will create a backup of this particular part of the registry.
Next, inside this Services folder, you should find keys for the Alcohol driver. Depending on the version of alcohol you had installed, these will be named either a347scsi and a347bus OR vax347s.sys and vax347b.sys
Delete each of the relevant keys.
Close regedit, then open the windowssystem32drivers folder & delete the files of the same names. (Or move them to another folder if you prefer, just in case!).
And presto they will be gone !!!!
on Jan 07, 2010 | THQ Alcohol 120% (alcohol120)
Alcohol 120% problem
format your pc it.........it is the bsod error
Jul 25, 2009 | THQ Alcohol 120% (alcohol120)
Alocohol 120% and Vista
did u try with Virtual CD s/w (latest)?
May 14, 2009 | Computers & Internet
Optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Can't burn data
if it is burning audio and video format it mean the burning is all right, u must choose some other application for burn data cd, like nero burning rom or alcohol etc.
Dec 22, 2008 | Teac (DW-224E) DVD Drive
Teac dw-224e-a dvd rom will not read dvd +r -rw data
Here's the newest driver for your burner. Go to Control Panel, then Device Manager, then click on the + symbol next to disk drives, and double click on the TEAC device. Click the Driver tab and press Update Driver, then choose the 'Let me find the driver' option, and navigate to the folder where you unzipped the file to. Double click and Install. Reboot.
http://www.softwaredriverdownload.com/download/driver/DW224E.ZIP
For burning, I would recommend Nero, Alcohol 120% or ImgBurn.
Good luck and Season's Greetings!
Chris (ziraffa)
Nov 13, 2008 | Teac (DW-224E) DVD Drive
Computers & Internet Logo
David Payne
David Payne
