Question about Dell Dimension 2400 PC Desktop
Would there be any 32bit PCI expansion slots on an IBM windows98?
Not sure of whether there are any PCI expansion slots on a IBM windows 98 PC, i am asking this because i am not entirely sure whether installing a wireless card in the Desktop PC is possible. Under the 'display adapters' in device manager, there is a 'S3 Trio32/64 PCI (732/764)'. Specs: 32.0 MB RAM, Intel Pentium Processor
THanks for the help!
  • ginger_man07 Jan 08, 2009
    Sorry for putting it in the wrong category. It's actually an IBM.
  • 948 Answers
There are PCI slots, but the processor, ram, and video capabilities are far below what modern components expect. You probably could get the wireless card to work, make sure the manufacturer has drivers for Windows 98 before you buy the card.
In my opinion you should maximize your RAM. For a Dimension 2400, Dell's manual claims the min is 128 Mb and the max is 1Gb. Not sure how you got to only 32Mb of RAM but you'll see a big improvement in performance if you increase it.
Do you have an old IBM or a Dell (the area you posed the question in)?
Posted on Jan 08, 2009
Install audio card for asus essention cg5270bp003 pc desktop
Three views shown.
Scroll down to the photos towards the bottom.
Looking at the Front of the computer, the LEFT Side panel removes.
Remove the Philips head screw located towards the Top, on the Side Panel's edge, and the Bottom screw on the Side Panel's edge.
Pull back on the raised fingergrip, formed out of the back of the Side Panel.
The panel pulls back so far, then is tilted out, and removed.
-> FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
You may also wish to remove all cables from the computer, and lay it on it's side for easier access to the motherboard.
Look at the right side of the motherboard, and the two long White PCI slots.
Above them is a long Blue PCI-Express x16 slot. This is used for a graphics card.
Above it is a small White slot. This is a PCI-Express x1 slot.
If a PCI slot is open you can use it for a Sound Card.
If not, and the white PCI-Express x1 slot is open, you can use it.
Examples of Sound Cards used in a PCI slot, and a PCI-Express x1 slot;
1) PCI;
On the back of the computer case framework is a small 'door', that holds the expansion cards in place.
The Thumbscrew is loosened, and this allows the door to swing open.
Find the appropriate expansion slot cover, that matches up to the slot your wish to use, and remove it.
Note that the expansion slot covers, do Not line up inline with an expansion slot on the motherboard.
(Expansion Slot; i.e., PCI, or PCI-Express x16, or PCI-Express x1 )
The expansion slot on the motherboard, is usually one space over from the expansion slot cover on the back.
[Don't believe that is worded correctly, but you will see what I mean with the Side Panel off, and looking at the motherboard ]
Yes. It's a lot of fun(?) trying to keep the expansion slot covers in place, expansion cards in place, and trying to close that 'door' properly.
[Look close. The bracket for the expansion card, (In this case a Sound Card), fits in little depressions in the metal framework of the computer case; or the brackets half-moon hole, will fit over a small peg, in the computer case framework ]
For additional questions please post in a Comment.
Oct 09, 2012 | ASUS Essentio CG5270BP003 PC Desktop
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
(Top right of your page, blue Comment)
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
What are the three expansion bus slots that are found on the mainboard?
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16) (Note 4)
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8) (Note 4)
  3. 3 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
(Note 1) Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connector by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When PCIEX8 is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
(Note 5) Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
(Note 6) Available functions in EasyTune may differ by motherboard model.
Feb 23, 2011 | Gigabyte GA890GPAUD3H AM3 Socket 890GX ...
Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Jul 06, 2009 | Fujitsu LifeBook C4135 Notebook
Samsung ml-2240 can not connect to windows98 driver
It won't run on Windows 98....very few machines are supported by windows 98 anymore.
Mar 04, 2009 | Samsung ML 2010 Laser Printer
Unsure of what type of PCI expansion slot in dimension 2400
8 and 16 bit PCI slots haven't been used in years so your slots would be 32 bit unless your PC is extremely old. That card will work fine.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Video driver for Dellm770 with Dell Optiplex110 - running Windows98
video si dependent on the video card you have. WIn98 is capable of 32 colors, therfore, you need to get a video card that is capable of giving 32 bit color.
as fa as digiital pic, you need at least 32bit if not 256bit. which win98 will have a hard time to comeup with.
I think it is time to upgrade.
Sep 26, 2008 | Microsoft Windows 98 for PC
Install Sound Blaster Live Card
Is the Soundcard already in the PC at the moment?
If you need help putting it in, let me know.
Here's an overview of driver for Windows 98. When the card is inserted in one of the PCI expansion slots you must install it's drivers. Windows will probably detect the card but doesn't know how to control it.
Here's the link I promised above:
[SoundBlaster Live! Platinum 5.1 Drivers and Software]
I hope this helps, need more help. Let me know.
Please rate.
Jan 28, 2008 | Microsoft Windows 98 for PC
Dell Dimension 2400 PC Desktop Logo
82 people viewed this question
Alun Cox
