Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops  Logo
alex Posted on Nov 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless radio off - Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops
Anonymous
Level 3:
  • Lenovo Master 32,281 Answers
  • Posted on Nov 20, 2012
Anonymous
Lenovo Master
Level 3:
Answers
32281
Questions
Helped
7907521
Points
102259
Check the Device driver for the wireless card. If it is not installed the install the wireless card driver.
The same model Lenovo can have different types of network, video and audio drivers and unless you know exactly which one is installed in your Lenovo, you need to download all the drivers and install each driver until you find the right driver. When you download the drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
How to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
4answers
HP 7410 MFP w/wireless. Need to unplug the wireless radio so the firmware will get "un-stuck" and start up the printer. How do I get to the wireless radio internally to disconnect then...
Hey,
If you can't navigate the printer menus when its stuck, I don't think theres anything else you can do but unplug it and try to update the firmware to solve this kind of a problem, Il look into the firmware
Thanks,
Ekse
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
I'm running Vista on my x31 2672 Thinkpad. I'm unable to turn on the wireless. I do not see a switch, what am I missing?
3answers
How do i turn on my wireless
If this information was helpful, please give me a big thumbs up when you rate my answer. Thanks!
1helpful
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Wireless radio turs off automatically
I have forgotton and need to reset the Bios password on a Tecra L2 S011 Labtop, can anyone help.
2helpful
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
1helpful
Wireless radio disabled
If you have a laptop and it has built in wireless adapter, it may have a switch or a button that you need to switch on in to turn on the wireless connection radio. Usually, it can be found on the sides or on the front panel of the laptop. On other laptops, you will need to hit some combination of keys on the laptop's keyboard to turn on the wireless connection radio, for example, Fn+F5. Please refer to the manual of your laptop for reference on how to turn on or enable its wireless radio.
By the way, what is the model of your laptop?
Wireless
There is no button on these, there is a setting in the wireless configurator that allows you to enable/disable the radio. Make sure the radio is enabled. Radio throws most people, all it is is the wireless card. The card works on frequency, so therefore is considered a radio, confusing, I know. If the radio is enabled or it still doesn't work after enabling it, you may have a driver glitch, then uninstall the wireless drivers from the device manager, and reboot. The machine will find the wireless and reinstall the drivers. This should get you up and running.
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
