Question about JVC TH-S3 System
Broken part(s) on rear of unit
I have a JVC home theatre surround sound system, model TH-S3. I have broken the thumb tabs for the "center" speaker terminals on the rear of the unit. They are where you plug in the positive (+) and the negative (-) ends of the speaker wire to connect the speaker(s) to the system. These tabs have spring tension, holding the positive and negative ends of the speaker wire against the metal in order to create a connection. With these tabs broken, I have no tension holding the wire ends in place where they should be (for connectivity). I have been using small tooth picks and jamming them in the hole to hold the wire(s) in place but would like to replace the parts in order to fix the issue entirely. However, I can't locate a part # for this piece, nor can I determine if I would be able to replace just the "center" speaker terminals or if I'm looking at needing to replace the whole panel of terminals for all of the speakers. Please help if you can. Any information as far as what part or parts I may need and what their part numbers are would be great. Also, any advice you may have as far as how to replace this part(s) would be great too. Thank you very much!!!
  • adambjohnson Jan 08, 2009
    Please help me with the part number or numbers I may need for replacement(s). I have a place I may be able to get the part(s) needed, but need to know what the part number(s) are. Also, please help with advice on how to actually replace the part(s) on the machine once I get them. Thank you.
    Thank you to all who helped out... I ended up with all that I was looking for. Thank you very much!!!
  • 2,071 Answers
You can buy the spare parts in electronics store. Just bring the parts as a sample. Hope it may helps..
Posted on Jun 10, 2009
  • 124 Answers
You can fix this very simply with electrical tape if you dont care about hope it looks just as you ha the wires jamed just use electrical tape to hold down the wires this should create a secure connection for your speakers and will sound good as well I hope this has helped you try looking on ebay for the part I have seen many speaker system parts on ebay might be just what you need
Posted on Jan 08, 2009
  • 492 Answers
With all the suggestions you have marked as not being very useful I would say that since all off this has not helped you that you should take it into a professional and have them order the part and repair the unit.
    Sergeant:
  • 378 Answers
To replace the part by yourself you will require a schematics diagram with you.this is the link for schematics just click and download the schematics for replacing the part yourself
http://www.eserviceinfo.com/downloadsm/18521/JVC_TH-S3.html
thanks.
good luck.
  • 916 Answers
The part number you need is 274-622 which is catologued at radioshack under the same number a link to that part is here
  • 15,935 Answers
It is a standard part a repair tech would have for around $40 you can have it fixed.
  • blueextc3221
    blueextc3221 Jan 08, 2009
    what more are you looking for here sir?
    All of your questions have been answered.
    If not, please reply with the information you require.
  • JVC Master
  • 19,396 Answers
You find the part list on service manual
Downlaod the two parts below, then join them using Winrar (Downloads):
JVC TH-S3 Service Manual free
Or buy service manual from: Service Manual, Schematic Diagram, Parts Catalogue
  • 716 Answers
Check Radio Shack For New Speaker Wire Holders.
  • 1 more comment
  • Michael Fisher
    Michael Fisher Jan 08, 2009
    5 Bucks
    http://www.radioshack.com/product/index....
  • Michael Fisher
    You Can But The Replacement Part For $20.95 Heres The Link
    http://tweeter.partsearch.com/Part/Matsu...
  • Michael Fisher
    I Found Another One $20.58
    https://www.ued.net/ued/addItems.do?item...
  • 192 Answers
Contact a stary shop.
  • Michael Ward Jan 08, 2009
    They should have a iteem descripsion so you know if it is the part you are locking for.
  • 4,472 Answers
I usually just solder a wire to it then connect the wire to the wire that i soldered to the connection. Makes it easy and you will have a secure connection. Easy, cheap fix. Not as cheap as those cheap plastic tabs though.
Thanks
Lee
    Sergeant:
  • 233 Answers
Welcome to fixya!
If you go to manualuniverse.com, you can download a service manual for this unit...once you have the service manual, you can find a part number for the speaker terminal block. Then you can go from there and order the part from the manufacturer or you may be able to find a parts house that carries it as well. Just google the part number once you have it, you'll be suprised to see what may pop up!
    Scholar:
  • 143 Answers
U need to change center speaker also do one thing if it's look nice then just flip both wair and put in there is no problem then it's running so no need to change nething....
    Sergeant:
    Scholar:
  • 199 Answers
Its 274-8463242 as per the service center manual.
thanks.
    Sergeant:
    Novelist:
  • 326 Answers
On the part which is broken there will be a alphabet written on it you have to check out that and refer that to the source which you had stated that can supply you a required part.just check out properly on the broken part a small number or a alphabet written on it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Would the speaker terminal you are referring to look like the image below?
If yes, readily available from most electronics part stores, even RadioShack.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 08, 2009
    It would appear that the center speaker terminal is part of an array of speaker terminals.
    Replacing would be a matter of getting the top cover off, marking where the wires or connectors go to and re-wiring/re-soldering the replacement speaker terminal array.
    JVC proprietary part number plus detailed instructions are available from the service manual.
  • Louie  Role
    Pls confirm with the actual part QNB0189-001.
  • 4,806 Answers
Hi there
You can get any part you want for your system here:
http://www.partmaster.co.uk/cgi-bin/search.pl?query=JVC%20THS3&brand=JVC&model=THS3&path=110448&model_pre=THS3
Good luck and thanks for using Fixya
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Problem with surround sound on JVC Th-C5 sound system
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
Dec 25, 2009 | JVC TH-C5 System
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Audio Players & Recorders
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Missing center speaker
Yes, you can connect all the other speakers and not have a center speaker. It will not damage the amplifier. But be aware, that many of the surround functions will not sound good without the center speaker. In just about every surround mode the center speaker gets more audio to it than any other speaker. It would sound better if you took one of the rear speakers and used it for a center speaker and have one rear speaker output no connected. The rear speakers get the least amount of sound going to them in all surround modes.
I hope this helps and a Fixya! rating would be appreciated. After all, it is the only reward we get for offering people like yourself free help. Most people never even bother to rate our free help here.
Thanks,
Dave
Nov 02, 2008 | JVC TH-M606 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Sep 09, 2007 | Audio Players & Recorders
JVC Home theatre system TH - S3
This appears to be a hardware problem in the video signal path.Have it checked by a technician.
ampere
Oct 29, 2006 | JVC TH-S3 System
JVC TH-S3 System Logo
215 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
