Question about Video Game Consoles & Games
Error being alert hook script runtime error,
Problem with Imagine Pet Hospital game from Ubisoft. Error come up when you go to pat the bird. Error being Alert Hook script runtime error: integer expected.
  • 61 Answers
SOURCE: Alert! Wrong Cartridge message
If you are absolutely sure that cartridge is installed correctly, the contacts where cartridge may be dirty. Clean gently with soft lint free cloth with small amount of rubbing alcohol and retry. If problem persists the contacts may have been damaged.
Posted on May 09, 2008
  • 63 Answers
SOURCE: error code 27
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it.
Posted on Jun 09, 2008
SOURCE: video game
Hi. I bought a game called PetVet2HealingHands. it keeps saying the same thing over and over!:Pixel Shader unavalable.
What do I do?!?!?!
Posted on Jun 12, 2008
SOURCE: Alert chipset heat sink not detected system halted error message
This is a relatively common problem in the Dimension 4600c. The small, fan-less heatsink for the Northbridge chip (a memory/video-to-cpu communications chip) is held down by a spring, which is anchored by two small wire loops soldered to the motherboard at locations marked "HS2". The spring completes an electrical circuit between the two wire loops. The spring puts a substantial force on the minscule bit of solder holding the loops to the motherboard, and was a poor design.
If a loop breaks off, the circuit is broken, which tells the BIOS that the heatsink fell off. To fix this, you need to 1) secure the heatsink to the chip, and 2) reconnect the circuit between the two "HS2" locations on the motherboard. I have sucessfully used this solution. This solution will not necessarly stand up to a lot of abuse if the Dimension's enclosure is frequently opened and closed to replace other components such as RAM and hard disks.
0) unplug the computer.
1a) Recover the heatsink, spring, and loose wire loop. Discard the spring. Get:
- a fresh tube of thermal paste from Radio Shack or other electronics supply store,
- some epoxy,
- a round toothpick,
- about six inches of insulated 14 to 20 gauge solid copper wire,
- electrical solder, flux, and a soldering iron,
- and a box of cotton swabs.
1b) Using pure alcohol and lots of cotton swabs, clean *all* of the existing thermal paste off of the Northbridge chip and the bottom of the heatsink. When both are dry, apply a dab of paste to the center of the Northbridge chip. Use a round toothpick like a kitchen roller to spread the paste evenly across the small raised center square of the chip.
1c) Apply small daps of mixed epoxy just outside of the four corners of the raised center of the Northbridge chip. Place the heatsink onto the Northbridge chip, centering and squaring it as best you can. Press firmly to make good contact with the thermal paste. Allow epoxy to dry.
2a) Firmly seat one or both detached wire loops into their mounting holes at the "HS2" locations. While pressing down on the loop, apply a small dab of epoxy to one end of the loop to secure it to the motherboard. Allow epoxy to dry.
2b) Strip the ends of the copper wire, and bend the wire so that it can reach around (rather than over) the heatsink to the two wire loops. Solder the ends of the wire to each loop. Knowing how to solder is an exercise left to the reader. "Use head main ting": don't drip solder onto the motherboard.
You can now plug in the computer and restart. The BIOS and/or OS may have saved the error state and return a different message about the heatsink issue. You may need to reboot a couple of times to allow the BIOS to notice that the "HS2" circuit is (hopefully) now complete. When you've sucessfully booted the machine, shut it down and gently close the Dimension's enclosure.
Posted on Oct 21, 2008
  • 72 Answers
SOURCE: dns error code 800
Try running through a router/gateway/switch then test your connection.
Posted on Dec 04, 2008
Error code 150-1031
This would not be a Ubisoft game? This is a general error code for a defective or unreadable disc. Go to the store where you purchased the game and exchange it or I could use their warranty to have Ubisoft replace the defective disc..
Nov 10, 2013 | Nintendo Wii U
Keep getting a box popping up talking about script errors. how do we stop that?
If you use Internet Explorer as your Web browser, chances are you have experienced, or will experience, popup script errors. Typically, a dialog box may appear stating "A Runtime Error has occurred. Do you wish to Debug?" or "Internet Explorer Script Error. An error has occurred in the script on line 1. Do you wish to continue running scripts on this page?" These errors can be distracting and interfere with your Web browsing experience. If you would like to stop receiving these error messages, you must modify your IE settings.
Open IE, select "Tools" and ten choose "Internet Options." The Internet Options dialog box will open. Click on the "Advanced" tab, scroll to the "Browsing" section and then select the "Disable Script Debugging" box.
Clear the "Display a notification about every script error" box under the same section if it has been selected. Click "Apply" and then choose "OK" to modify your IE settings. You will receive no more IE script error notifications. Hope this helps.
Jan 01, 2013 | Microsoft Internet Explorer 8
Runtime error in setup script line 3 @address 77C0154D in module 'version.dll'.
sounds like malware, download and run malwarebytes from then download and run combofix from you'll have to reset your winsock as well by downloading and running winsockfix.exe you can find it by googling. use a different computer and put it on a flash drive :)
May 31, 2012 | Linksys Wireless-G WRT54G Router
On call of duty black ops it wont let me play campaign comes up with 'client script runtime error (see console for details) cant use entity before recieving first snapshot'
Well if you had your wii hacked you are going to see this more often, as more games are putting in this kind if protection. Even if you are running just the homebrew channel, they are cracking down... hard.
Dec 30, 2010 | Nintendo Wii Console
I have directx 10 but still can not fix the Runtime Error 429. What should i do?
Error 429 issue is caused by corrupted Windows registry.
The first tips to fix runtime error 429 is to run security scan on your computer.
Repair your system's registry with
Also you can try to go to the Microsoft Windows Script update page to fix runtime error 429.
If possible download XP SP3
Hope my solution will help you...
Have a Nice Day
Oct 13, 2010 | Individual ResumeMaker Career Edition for...
Everytime i open iternet windows script host appear with the following data: Line 24, Character 1, Error permission denied, Code: 800A0046, Source:Microsoft VBScript runtime error. Please help me to solve...
It is a Windows Internet Explorer bug that could be fixed by upgrading your IE to version 8. Also, check your "home page"found at Tool => Internet Options and set it to some legitimate website. The error message simply means that the page you are viewing has scripts that return an error.
Feb 02, 2010 | Computers & Internet
Everytime i log out of the internet i get the following error coming up on my screen 'iexplore.exe application error' when i click on this to get rid of it i then get an 'runtime error' message and...
Goto Control Panel>>Internet options -Uncheck the following options Disable script debugging(Internet Explorer) Disable script debugging(Others)
Enable third party browser extensions
Mar 17, 2009 | Computers & Internet
Runtime error
relax ekse... :)
specifically what type of runtime error did you encounter joe?
to make things easier for you. install java, install flashplayer, upgrade your browser. this may help you with that runtime error. my best guess is this is a script runtime error on IE.
what do you think ekse?
Jun 03, 2008 | Computers & Internet
Video Game Consoles & Games Logo
545 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
