Question about Sony Playstation 3 (PS3) Console
Can't set my ps3 NAT type to type2 - Sony Playstation 3 (PS3) Console
    Problem Solver:
  • 4 Answers
If your using a wired router,try putting in the username and password for your PPPOE.mine was nat 3 and went to nat 1 after i done this.check out youtube.let us know
Posted on Feb 12, 2009
  • 53 Answers
You are not able to set the NAT Type, the ps3 reads your internet and tells you which NAT Type it is
Posted on Jan 09, 2009
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
Jan 18, 2011 | Video Game Consoles & Games
My nat type on my Playstation 3 is nat type 3 (strict). I would like to know what setting configuration on my WRT54GX router so that the nat type decreases.
Well this becuse of NAT on the router
you can solve the problem by putting your PS3's IP address on DMZ in the router
access your router page (type 192.168.1.1 in the address bar of internet explorer)
username would be admin and password would also be admin
go to the DMZ and enter the IP address of the PS3 there after enabling it....restart your PS3....bingo your problem solved
Note:- you can check your PS3 IP address in the network settings and connections option on PS3
Hope it helps
Thanks
Jan 16, 2011 | Linksys Wireless-G WRT54GX Router...
How to change nat type3 to nat type2 for ps3?im with eircom ireland
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 15, 2011 | Netopia Computers & Internet
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
I have a netgear WNDR3300 and my ps3 has a NAT type 3 how do i get it to a type 2?
You have to manually set the NAT type of your PS3 to type 2. I believe you can do that thru the interface. Most routers has NAT 2.
Feb 22, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Jul 15, 2008 | NetGear WGR614 Wireless Router
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
574 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
