Question about Kenmore 92002 / 92004 Kitchen Range
Sparks flew out EOC for Kenmore model 790.90819404
I had preheated the oven for about 10 minutes. When I turned the timer on, the display sparked and the whole oven won't work. My husband pulled the EOC off and it was burned where the bake wire goes in. We replace the EOC and put the wires in the correct location and oven still doesn't work. Any suggestions?
Thanks
  • 1 more comment
  • adams_dubose Jan 08, 2009
    No the EOC does not light up.
  • artiacousmc May 11, 2010
    Does the EOC light up when powered on? If so, could you turn the breaker off, unplug 1 wire from the bake element and carefully place it away from any metal, turn breaker back on, then turn on the bake at EOC. Using multimeter, take voltage reading from unplugged wire and the other plugged in wire at element. What's the reading?
  • Anonymous Mar 13, 2014
    how do the wires go.. yellow blue black, or blue yellow black?
    Sergeant:
    Champion:
  • 338 Answers
Check for voltage between L1 and neutral if you have 120v the the eoc should work. if you do not you may have a bad terminal block.
Posted on Jan 10, 2009
Replaced the EOC and reset the breaker.
Posted on Jan 09, 2009
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
Oven controls not working , just clock on display
Good Morning kJordan!
FixYourBoard can likely help you with your unit. They'd remanufacture your part in 1-2 days, fully test the unit.. and back their work with a 2 year warranty. http://www.fixyourboard.com
Mar 29, 2017 | Kitchen Ranges
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
WHIRLPOOL SUPER CAPACITY 465 SF385PEGZ3 NO OVEN/BROILER
sounds like an issue with the spark module, altough that module tends to be really relliable.i would try removing pawer to te unit. checking the outlet for proper grounding,and replugging unit see if that works for you
Oct 25, 2008 | Whirlpool GS460 Gas Kitchen Range
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Whirlpool gs475lems range oven problems
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Dec 02, 2007 | Whirlpool GS475LEKS Gas Kitchen Range
F4 code when preheating oven
That code means "Shorted Oven Sensor". You can find out more about this by removing the bottom drawer, pull it out til it stops, lift it up and pull it all the way out. Now lay down on the floor and look under the oven to the left side. You will see a service info card there. Pull it out, open it up and have a read.
Oct 06, 2007 | GE JBP80 Electric Kitchen Range
Oven not working
Gas Burner valves use a flame proving circuit to verify that a flame exist before releasing gas to the burners in the oven as a safety precaution, this sensor being exposed to temperature extremes, fails over time.
Aug 27, 2007 | Kitchen Ranges
Oven temperature fluctuating
Glowworm, Im assuming your model is a 790.78802500. If your husband is handy with a meter have him ohm out the sensor. It should show around 1091 ohms at 75 degrees or room temp. The preheat is programed so that the manufacturer can get the energy effecient label on the range and what ever perks they get from it. It actually should take around another 10 to 15 minutes to reach the set temp after it shows preheated. You can calibrate the oven by setting bake to 550 degrees. Then press and hold the bake pad again for 15 seconds or until a single beep is heard. Now you can adust temps up or down in 5 degree increments up to 35 degrees by using the slew keys. It will show in the display. Once you have the calibration done, press stop/clear. Catriver...post back
Nov 01, 2006 | Kenmore 78802 / 78804 / 78809 Gas Kitchen...
Open Questions:
Inner part of Triple element on 790.9912940 won't turn on I just experienced the same problem I've been reading about here and on other appliance repair sites: the inner element of my Kenmore Elite's front-right triple element will not turn on, despite the control panel saying it's "on." The range is about 2 years old, just like many other people have said. Also, Sears naturally wants to charge $65 to even come look at the part, and then several hundred more for a new element. From reading other comments and after talking to Sears, it seems like there is no extra warranty or recall on this part. This triple element is apparently a defective design if I can find so many reports of this exact same issue with only a cursory Google search. Would not have bought Kenmore anyway if it hadn't come with the house, because I've heard of this kind of thing with them far too often, despite their obvious good looks and nifty features... I'd rather not have to spend hundreds of dollars just to keep my $1.2k range working properly - for that price it should have a 5-year warranty at least in my opinion. I'm going to see about removing the element and putting in a new one on my own, as getting the part itself (Sears Direct Part Number 316216702) is only about double the cost of getting a technician to come out in the first place. You can see a handy part diagram of the range top at this link, by the way: http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0610001-00003.png The element that has failed on my range is part 15B in the diagram.
Sep 08, 2009 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 92002 / 92004 Kitchen Range Logo
253 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
