SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
SOURCE: computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
SOURCE: I have an Hp Pavilion a1600n Pc No Video INput signal at start up
Hi, the problem you have, maybe the Graphics card within the computer, if you try another graphics card and it works this cold solve it.
If you try using your dads pc's graphics card to test this may be useful to determin the problem.
Hope this helps!
SOURCE: Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
I made various test:
cpu (pentiun e2180) pass the test mounted on another PC.
I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
Some of this Acer model have this motherboard crash
look also here
http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
Change the MotheBoard
