Question about Datalogic Gryphon D200 (901661076) Handheld
Scanner isn't scanning all the time
We have scanner that we use to scan barcodes. Before the scanner instantly recognized the barcode with in seconds. Now the scanner doesn't seem to be scanning properly. It will scan a barcode every now and then. About 10 out of 88 times. Does the scanner need new batteries or does it even use batteries? If batteries are the answer what type? Thanks
  • Anonymous Mar 20, 2014
    scanner connected scans barcode but nothing displays
    Sergeant:
  • 279 Answers
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
Posted on Aug 28, 2007
Is it possible to make auto enter after second barcode scanned
Hi. Read your scanner's manual as the manual should contain a barcode for "automatically press enter after scanning a barcode", or a shorter name. Once you scan the barcode, it will activate the function on your scanner.
We did this for our motorola scanners pretty fast after purchase.
Dec 15, 2014 | Computers & Internet
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
I have a barcode scanner Symbol S/N M1J82M51E. When scanning the item barcode it makes very low volume. How to increase the bipping scanning volume for the Symbol Scanner?
1. Press and hold the trigger for an extended period of time (approximately 5 seconds). The scanner cycles through three settings (Low, Medium, High) emitting a 2-beep tone at each setting.
2. To select a particular setting, release the trigger after you hear the desired 2-beep tone.
Sep 18, 2010 | Symbol LS9208 Hands Free Barcode Scanner
My Symbol scanner sits in a cradle, and the laser goes off and on, rather than remaining on full time. This is a problem, because when I pass a barcode under the unit, I have to wait until it flashes, and...
Yes Symbol LS2208 would be the best... it has an intellistand that enables presentation scanning and easy switching between hands free and hand held models..
Nov 16, 2009 | Symbol LS3478 Barcode Scanner
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
Jul 12, 2009 | Symbol M2004 Barcode Scanner
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Datalogic Gryphon D200 (901661076) Handheld Logo
735 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
 Ian Kayhan
Ian Kayhan
ray gallant
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
