Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Where can I find a power-on chip for 52" Mitsubishi WS-55809?
I broke the chip when I was trying to clean back of the screen. Can I also install it myself, or do I need to have a tech do it? If I can do it myself, just how easy is it?
  • 133 Answers
You can go to Mitsubishi . com. get the number for the parts dept, or can order it on line, should be prity easty to do yourself, just tale all of the screws from areund the screen, from the back, there may be a couple in the front at the bottom of the screen, then lift up on the screen and remove it, should be able to replace from there, a service center would charge you around 200$
Posted on Jan 08, 2009
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
I need to replace the convergence chips in my Mitsubishi WS-55809. Could someone send me the instructions to do so, as well as any other need info for this task? Thanks, Jason utilitypigeons@aol.com
There should be a diagram somewehre in the tv set itself. If not, do a diagram search on your model number on your television, and it should show where those chips are.
Nov 23, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi WS-55809 justs has a blue screen. I think I may have accidentally changes something to 1080i. Hos can I reset it?
Your televison might be stuck in Home Theater Mode.
If so can you pull up the menu.
Please post back so I can help you further.
asnowman
Oct 11, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809 convergience
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Cobwebs behind the screen of a 55" projection screen. How do I remove screen to clean the TV? I have a Mitisubishi WS-55809.
Hello morsec,
You will need to remove the screws on the back of the top half of the TV set. This will allow you to remove the top rear half of the TV and give you access to the screen. Make sure you do not break the mirror that is attached to the rear of the TV set. Clean the screen with a damp non-abrasive cloth dry with a dry non-abrasive cloth. When finish replace the back of the TV and tighten the screws to hand tightness.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 installing STK392-570
un solder ics replace both of them resolder make sure you do not solder any of the circuits together or it will short something out,also ck low ohm resistors in same circuit.I will try to help you the best that i can. Main key you must know how to Solder.
Dec 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Ws-55809 Convergence chips
If you are looking from the back there are 3 circuit boards, the one on the left is green and the other two are tan. The middle on is where the stk's are they are mounted to that big metal heatsink in the middle of the middle board. If you cannot located them email me a picture and I will circle it.
Thanks,
Tim
experttv@comcast.net
Oct 04, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Convergence problem, then no power...
Hi! Truman001;
Check all the peco fuses on the deflection /power pcb.
Please let me know what you find.
Thanks!!
Toprol
Oct 15, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
