Related Tags:
This problem should be removed because:
Problem with Apple iPod nano White MP3 Player
Do Not Disconnect message will not disappear
I have a problem, why does the "Do Not Disconnect" message appear on my iPod even though all transfers have finished and iTunes has been closed?
Solutions (8)
Best Solution
There are several things you can try:
1. First and most simple way of solving this common problem is pressing the menu and center button for about 6 seconds.
2. If iTunes is open, close it and see if the message disappears. If it's closed, try to re-open it and click the "eject" icon on the lower right of the screen.
3. Go to My Computer, right click on the iPod icon and select "Eject". If the message still appears, open your Task Manager by clicking Ctrl+Alt+Delete (at the same time) and under the "Processes" tab close and program that looks like it's related to your iPod.
4. If nothing else worked and you've tried all of the above ? just disconnect your iPod. Make sure you've closed all the programs related to it through the Task Manager, as explained above.
This has to fix it.
It is because of the way a computer connects through USB (assuming you are using a PC, I imagine Macs are the same way, but I don't know for sure). There is information being passed back and forth between your iPod and the computer even when iTunes is not being used. I've never seen any problems with simply disconnecting the iPod in Windows XP or earlier, but if you're using Windows Vista, not ejecting through iTunes has been reported to cause the data to become corrupt on the iPod (even using Windows "Safely Remove Hardware" button).
When you need to disconnect your iPod you need to press the eject button from within iTunes. It only takes a few seconds and everything comes out tidy.
Thanks!! Amazingly simple. You should write the instruction booklet.
this is only a temporary solution. once i reconnect the ipod and select "sync music", the problem resurfaces.
I did #3 and then #1 and it worked, all the music is gone now but i dont care i can re upload it :) thanks.
thanks for the great solution I did #1 and it worked!!! I didn't think it was so simple
Thank you sooo much!!!!
I HAVE A 20 GB IPOD AND WHEN I CONNECTED,IT SHOWED ME A MESSEGE do not disconect
pc to ipod
how can i download from pc
IPOD NANO HARDISK MEMEORY
MY IPOD NANO MEMORY IS FINISH 4GB CONVERT IN TO 0 BYTES SO WHAT CAN I DO
Ipod wont sync
I plugged my ipod into my computer and itunes said that it synchronized but it didnt and none of my new music is transferred on. It took off...
itunes does not recognize the ipod when plugged in...
ipod does not sync. itunes will not allow more songs and there is memory available
Add Your Solution
i don,t know my password
please help me
nano doesn't sync
nano doesn't sync
Fix-O-Meter
6,681
6,681 people viewed this problem
- 51 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Apple MP3 and Digital Media Player Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
