Booting from usb flash drive
What would i do to boot operating system using usb flash drive and how to make a bootable usb
  • Thomas F. Schneider May 11, 2010
    Go to your help section of your windows. Type in "Boot Disk"  Follow the directions only where it says disk use the flash drive?
  • 416 Answers
A step by step guide to create a boot disk
http://www.csd.dficlub.org/forum/showthread.php?t=1136
Posted on Jan 08, 2009
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
Free usb reboot
You might want to boot from a USB device, like an external hard drive or a flash drive, for many different reasons.
When you boot from a USB device, what you're actually doing is running your computer with the operating system that's installed on the USB device. When you start your computer normally, you're running with the operating system installed on your hard drive - Windows, Linux, etc.
How To Boot From a USB Device
Change the BIOS boot order so the USB device option is listed first. The BIOS is rarely setup this way by default.
If the USB boot option is not first in the boot order, your PC will start "normally" (i.e. boot from your hard drive) without even looking at any boot information that might be on your USB device.
Tip: The BIOS on most computers list the USB boot option as USB or Removable Devices but some confusingly list it as a Hard Drive option, so be sure to dig around if you're having trouble finding the right one to choose.
Note: After setting your USB device as the first boot device, your computer will check it for boot information each time your PC starts. Leaving your computer configured this way shouldn't cause problems unless you plan on leaving the bootable USB device attached all the time.
Attach the USB device to your computer via any available USB port.
Note: Creating a bootable flash drive or configuring an external hard drive as bootable is a task in itself. Chances are you made it to my instructions here because you know whatever USB device you have should be bootable after properly configuring BIOS.
  • Restart your computer.
  • Watch for a Press any key to boot from external device... message.
  • On some bootable devices, you may be prompted with a message to press a key before the computer will boot to the flash drive or other USB device.
  • If you do nothing, your computer will check for boot information on the next boot device in the list in BIOS (see Step 1) which will probably be your hard drive.
Note: Most of the time when trying to boot to a USB device there is no key-press prompt. The USB boot process usually starts immediately.
  • Your computer should now boot from the flash drive or USB based external hard drive.
Jan 02, 2015 | Computers & Internet
My sony vaio wont boot from external drive
Go into the BIOS and make sure that USB is selected for boot options.
Mar 14, 2014 | Computers & Internet
How to restore image by using bootable usb oc dvd
I prefer installing/upgrading the operating system on the ix104c2 with a USB flash drive and the program "WinToFlash" and set the "Hard drive priority" to whatever flash drive you are using as the first boot device in BIOS. I recommend using a USB key board to navigate BIOS and it is required to install the Operating system.
Dec 18, 2013 | Xplore Technologies Xplore iX104C2 Tablet...
How do I reboot if it wont restart.
You can boot it up with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB Flash Drive and boot up Operating System from bootable CD/DVD/USB Flash Drive directly.You can use it to retrieve data under any boot up problem.Get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Aug 04, 2011 | Gateway GT5694 Desktop Computer
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
This means you should install an Operating System.
If your notebook doesn't have a dvd drive you can install the Operating System with an external drive (dvd, USB flash drive or hard drive). and press F12 when it starts to select the booting device.
Follow the link below to find out how to create a USB flash drive bootable (also works on hard drives):
http://forum.bstdownload.com/how/55-how-create-bootable-usb-stick-when-using-windows-vista-windows-7-a.html
Feb 01, 2011 | Acer Aspire One PC Notebook
I was trying to boot my pc from usb but it was noot bootable how to make usb drive bootable
Have had loads of usb media, as far as I know some USB sticks are bootable others are not, usually it will say either on the manual or on the box of the product whether its bootable. If it is bootable format the usb drive fully then copy the BOOT.INI, NTLDR, and NTDETECT from the root directory of your PC's boot drive to the flash drive. These files are hidden by default, so you will either have to configure Windows Explorer to show hidden files (including protected operating system files) or you will have to open a Command Prompt window and use the COPY command to copy the files. If you choose to use the Windows Explorer method, then open Internet Explorer and enter C: into the address bar so that you are looking at your local hard drive. Next, select the Folder Options command from the Tools menu. When the Folder Options properties sheet opens, select the View tab. Now, just select the Show Hidden Files and Folders and deselect the Hide Extensions for Known File Types and the Hide Protected Operating System Files check boxes. Click OK to continue.
Now that you have formatted your USB flash drive and installed the boot files onto it, the next thing that you must do is to configure your PC to allow you to boot from the flash drive. This is all done through the computer's BIOS Setup. I can't give you specific instructions for this part, because every computer is different. I can give you a few pointers though.
You can access your computer's BIOS by pressing a specific key immediately after you turn the PC on. The key varies, but it is usually either [F1], [F2], or [Delete]. Once you are in the BIOS Setup, you should verify that all of your computer's USB options are enabled. This might include things like support for legacy USB devices or support for USB 2.0. If there is a time out setting for USB devices, you should set it to the max to insure that the system doesn't time out while waiting on the USB device to boot.
Next, find the section on boot device priority. Normally, a USB flash drive (which is usually listed as USB-HDD, but may be listed as a removable device) will have a very low boot priority. If the USB flash drive's boot priority is lower than the hard disk (listed as HDD) then the only time the computer would ever boot off of the USB flash drive is if the system were to fail to boot from the hard disk. You must therefore rearrange the boot device priority so that the flash drive has a higher priority than the hard drive.
Jul 01, 2009 | SanDisk Computers & Internet
How can I make my USB bootable?
Boot your computer.
Insert your USB device.
Follow the instructions for your particular operating system (it's different for each OS) about making a bootable device.
Install an operating system on your USB device
Set your BIOS to boot from USB (again, the exact process is dependent on your particular hardware, different for every motherboard/manufacturer.)
Feb 22, 2009 | Electronics - Others
Bootable files
When a computer is powered on, the BIOS ("basic input output system") has only a few commands available to it, and the main one is to search for a "boot device" - a storage device which contains "bootable files". The first device it finds with "boot records" is used to load the operating system.
Usually this is the C drive, but could also be a floppy, USB flash memory, or CD.
In order to get the boot records onto a device, a special option must be used when the device is formatted. This boots the boot records in a place where the BIOS knows to look for them.
So, a bootable file (or "bootable device") is a storage device which has been set up with these boot records.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
