Question about Dryers
Dryer doesn't heat up
Dryer sounds normal, but isn't heating. Thus not drying the clothes
  • stephanyreed Jan 08, 2009
    took the back panel off and found that the coil was broken
  • 686 Answers
Heating element went out sounds like to me
Posted on Jan 08, 2009
  • James Chandler Mar 01, 2009
    if you found it to be broken plz give me a fix-ya rating ty
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Heating but not drying, doesnt seem to be blowing very strong through dryer vent
Hi cipera11...
I think your problem is a clogged or cogging vent
Heating Element
Cycling thermostat
Please take time to rate me thumbs up.
Sep 11, 2011 | Amana Dryers
Cloths are not drying in one cycle and need to extend the time of the drycycle not sure how? Model no dcd330gy1wc
Hi demetriosqat...
Sounds like you have a Clogged Vent or Heating Element problem.
Heating Element
Cycling thermostat
Sep 10, 2011 | Dryers
Taking a long time to dry.
Hi dawansd
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
May 25, 2011 | Dryers
Clothes are real hot to the touch
sounds like you have a venting problem,, check for clogs or blockage in the vent pipe,, and also at the exit from the house to be sure the vent cover flows freely and isn't smashed down. check inside this vent to be sure the flap inside of it moves freely and isn't stuck,, Normally when clothes get hot to the touch its caused by the clothes heating up to dry and the moisture isn't allowed to be vented out
May 24, 2011 | Whirlpool Dryers
The dryer heats up but doesnt dry the clothes... what could be the problem
Hi rissa306
Clogged Vent
Heating Element
Cycling thermostat
May 23, 2011 | Dryers
Kenmore dryer...model # 1108262101 clothes not getting dry...normal dries better than perm press but still not as good as before....where do I begin? Thanks, Mary
Hi lkyldy31...
Your dryer is acting like it has a Clogged Vent
Heating Element
Cycling thermostat
Apr 22, 2011 | Kenmore Dryers
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Heating Element
Cycling thermostat
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
The Dryer has hot air but the clothes are not getting dry?
Clogged Vent
Heating Element
Cycling thermostat
Apr 14, 2011 | Maytag MDE6000 Dryer
Dryers Logo
Top Dryers Experts
