Question about Kenmore Elite 45986 Front Load Washer
Error code LOC on kenmore front load washer
Washer will not start and flashes error code LOC
  • 15,935 Answers
Press/hold LOCK for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • John Stammreich
    John Stammreich Feb 10, 2014
    Thank you very much! This remedy is NO WHERE to be found in any of the manuals that came with the machine!
Flashes LOC and won't start
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in
Nov 08, 2012 | Kenmore Elite 45986 Front Load Washer
Washer is reading LOC and the error button flashes every time I try to cancel. It just started before the cycle began
I am not sure if this will solve your problem but it did mine. Press and hold the option and select button at the same time until the Loc goes off. It should fix your problem..... Hope it helps you...... Good Luck
Sep 14, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Kenmore he3t front load washer time flashing stuck
Take the front panel off your washer. Inside the washer attached to the side you should find a manual that will help you with the error codes.
Aug 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore Elite 45986 Front Load Washer Logo
1,234 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
