Question about RCA P52926 52" Rear Projection Television
1995 RCA Rear Projection TV tuner adjustment
The dvd player and video games are clear and some channels are too but some are really fuzzy how do i fix that
    Scholar:
  • 73 Answers
You are seeing the difference between Digital signals and analog signals.
Get one of the new Digital boxes, everything should be as clear as the other sources.
This is one of the benifits of the digital conversion that is going on,
Charles
Posted on Jan 09, 2009
Rca j25420 (Older device)
Basic DVD player connections consist of three wires: Right audio (red), left audio (white), and video (yellow). These plug into corresponding connections on the rear of the TV. Your RCA TV may be so old it does not have these input connectors on the rear. Tne "game channel" you are attempting to find does not exist.
Dec 18, 2013 | Televison & Video
The screen is fuzzy all over
try a dvd or vcr if it clears it the tuner board
Jun 07, 2010 | RCA D61W20 61" Rear Projection Television
The picture quality is fuzzy at the lower left of the screen. Also, the DVD picture is off center. How can I adjust or reset both?
This indicates an Automatic Gain Control (AGC) problem often caused by a dried up capacitor. You will probably need a schematic to go much further. This could be a problem in the tuner, IF, or video amplifiers.
The following assumes you are sure the signal source is strong - try a VCR or other local one (channel 3/4, not the RCA jacks).
Most of the time the range of AGC is from 1 to 7 volts. If you can get a decent snow free picture with an external AGC source, then the tuner is probably OK.
May 21, 2010 | RCA D61W20 61" Rear Projection Television
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Jun 30, 2008 | RCA P52926 52" Rear Projection Television
Can't get any channels on the air.\
If the tuner is the problem then it is a very bad problem as the tuner is part of the DM module and that is very expensive. When you say you have to manually key in the channels, do they work then? If so the problem is not the tuner. If your only problem is that you cannot go from one channel to the other by using the channel up and down button on the remote, then you have most likely just lost the programming on the tv. Go into menu and set up and find the auto channel programming and run auto program to correct the problem.
Apr 28, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
RCA P52926 52" Rear Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
