Question about Canon i9900 InkJet Photo Printer
Canon i9900 Printer Trouble
My printer is suddenly making a terrible grinding noise when I try to print something. Some paper did jam, but got that out. What should I do? I purchased this printer less than 1 year ago. Thanks for any help you can give me. I turned the printer off and then on several times - still makes noise!
  • Geraldine Naunheimer Jun 03, 2007
    Got in touch with a tech at Canon and a replacement is being sent to me as the problem was not fixable. Thanks for your suggestion.
I had the same problem. I tried to clean up, even spray WD40 into some parts. At last I clicked on Quite Mode under properties and select Always use quite mode. I don't remember exactly how I did it. First time it looks gray out with no choice but later I could select this option and looks like printer overwrite something after that the ugly sound was gone. Good luck.
Posted on Aug 28, 2009
    Genius:
  • 2,985 Answers
Less than a Year ago - You mat have a chancefor a ree replacement under warranty terms - check out where you bougth from [you do have the bill dont you?] Also get on to Canon Tech Support team Also take a look at www.fixyourownprinter.com
Posted on May 31, 2007
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
Paper jam made horrible noise, now no power
that's the mechanism in side rebelling..I'd recommend you have a qualified service person handle this one.
Aug 04, 2008 | Canon PIXMA MP600 all-In-One InkJet...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Canon i9900 InkJet Photo Printer Logo
236 people viewed this question
old marine
old marine
