Question about Ruud UBHC Air Conditioner
Problems with a new Ruud heat pump "wiring"
I have just replaced a train heat pump condenser with a Ruud UPNE 042JAZ. The existing gas furnace/ coil is being used, the furnace has a heat pump add on box mounted on its side. The wires coming out of this box going to the old condenser (6 wires) are as follows:
Box y to yellow on condenser
Box #2 not connected
Box #1 not connected
Box R to red on condenser
Box X2 to brown on condenser
Box O to orange on condenser
Box T to another brown on condenser
Box B to blue on condenser
So I have 6 wires coming outside but only have 5 wires on the ruud
unit, the ruud condenser has a yellow, red, blue, purple, and brown.
Not sure what connects to the ruud unit, what is the purple and blue wires? What does the T stand for on the thermostat and that aux. box?
The furnace must not have been heat pump compatable the reason the aux. box was installed? Is this a common retro fit? I've installed many A.C systems but this 1st heat pump is kicking my but.
Help me please!!!
Any info will be appreciated.
  • 24 more comments
  • Anonymous Mar 11, 2014
    RGB" 52 Logik splay red and yellow pictures
    change credit card details
    It won't start
    haier dishwasher code e6
    how do you remove the aggitator on a ge profile washer
    The dough setting on my machine doesn't seem to work. All the ingredients just sat there for about 40 min with no mixing. Any ideas?
    Hytech HT 7520 20MP Web camera driver
    PLT7044K-B driver
    Need a wiring diagram for jet 2 power chair control panel
    when I type in an email address I do not want any predicting of a previous email address
    What. Can I substitute for beer
    washer will not empty after wash cycle, washer full, smells hot, humming
    hotpoint oven door remove spring hinge
    I have replaced the carrier bearing in the sprocket hub,there are no teeth missing in the sprockets. The chain is has about 6000 miles on it. I recently changed the rear tire. I never noticed the problem before then. But it seems to be getting gradually worse. I have also made certain that the rear wheel is aligned properly. This is my transportation to work. Any help is greatly appreciated. Thank you.
    the head lights asembly have water iwant to now how to remove
    how do you delete missed messaes model #cs6719/cs6719-16/cs6719-2 DECT 6.0 cordless phone
    para ganar 100 minutos gratis como le puedo hacer
    Intelli fax 3840
    lenova g550
    Fuel consumption varies from 410m per tank to 310m on my new car, a citroen c4 vtr. It appears to depend on what sort of driving i'm doing; motorways 400+; noraml use 310, but seems to last for about a tank full of fuel after I return to normal use from motorway driving?? I've owned a 1.6vtr xsara prior to my 2006 c4 vtr, both have the same size fuel tank and very similar engines. The 400+ per tank was always maintained by the xsara, the c4 is mostly doing 310. A lot of difference! Do you know what it could be? And Is there computerised fuel management with this model?
    Brand new cobra 19 ultra 3. I hear everything on the road but can not communicate at all. I have a solidsignal 18ft antenna wire and a firestick antenna. good ground and power,
    Motor runs fine and starts no problem but there is the same amount of watert pressure going in through the hose opening as there is leaving the nozzle. Have opened up the 6 caps on the pump inlet and outlet and have cleaned it out for any contaminents. Still no luck with the pump producing pressure. What can i do next?
    I was driving in the middle lane last Wednesday with my granddaughter in heavy evening traffic when suddenly the car lost power. Luckily I was able to drift to the side and stop between the yellow line on the right and a concrete embankment on the left. I was scared and waited a few minutes until I could regain my composure and started the car which responded immediately and then drove home. Jamie and I came within seconds of causing a horrific accident and being killed. This loss of power has occurred seven times in the past four months and each time I have taken the car to be repaired (I have all the paperwork) and each time I think the problem has been resolved. A few days ago I heard about the recall on TV and yesterday I took the car to Coggin Buick of Orange Park, Florida, and had the ignition cylinder and key replaced for which they charged me $386.05. They informed me that it would not to done at no charge as my 1995 car was not listed in the recall even though I had been having the same problem for four months. This problem was originally diagnosed November 15, 1913, at Suttle Motor Corporation in Newport News, Virginia. They did not tell me of their knowledge of this problem and of the recall. There was a solenoid on the transmission which needed to be replaced and I had that done for which I was charged $1070.66 plus $125 for the diagnostic test. I took the other keys off of the ignition ring which, I thought took care of that problem. I have had the car towed when it lost power and wouldn't start back up. I replaced the starter, another expense. I think most of this could have been avoided had Suttle Motor Corporation simply replaced the ignition. I have suffered a lot of mental anguish always looking for a place to park in case of a power failure especially when my grandaugter is in the car and I could ask for compensation for that and for the other expenses I have incurred but the other problems with the car my have occurred anyway. I am asking for $386.05 which I paid to have the ignition replaced and $32.05 for an extra key. Thank you for your consideration. My email address is bgallagher923@gmail.com. I am Barbara Gallagher and my address is 9167 Axson Street, Jacksonville, Florida 32221.
    window doesn't open
  • Anonymous Mar 12, 2014
    what do I need to replace the antenna input cable part or repair manual
    why will the 4WD light not come on when i put my 2004 diesel 3500 duramax in 4WD
  • 177 Answers
Hello and welcome to FixYa!,
It sounds to me like there may be a fault with the Furnace or that the Furnace is not compatible with the Heat Pump.
It may also be a faulty Heat Pump.
Hope This Helps, --P3NGYJ03
Posted on Jan 08, 2009
  • 8,220 Answers
Wow
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
Ruud upne-042jaz fan not starting
If the fan motor is not starting it may be the capacitor located behind the electrical panel on the outside unit. These are relatively inexpensive and easy to change. You can disconnect the power to the outdoor unit and remove the capacitor. Take it to your local HVAC wholsaler or contractor and have them check it. If its bad it should run you 20 to 30 dollars to replace. If it is not the capacitor then it may be the fan motor. If the blade turns easy it means the bearings are fine. One of the windings may be open thus making it able to turn but not run when power is supplied. I think this is a heat pump and there may be a control board on the outdoor unit which may control the operation of the fan. I have not found a wiring schematic for the unit yet. Once I find one I will let you know. The problem listed above is very comon and inexpensive for you to fix. If it is something other than the capacitor, I would call you local NATE certified technician and get her looked at.
Jun 06, 2010 | Ruud UBHC Air Conditioner
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
Recently changed thermostat on gas furnace w/ cent air
Unfortunately, a strick standard does not exist for wire terminals and colors. However, there are "norms" which I will be happy to share with you.
Red - Rh & Rc (Jumpered)
Blue - C
Yellow - Y
White - W
Green - F
Note: this is assuming you have only ONE transformer in your low voltage circuit for both heating and cooling. If there is a low voltage transformer at your outdoor unit you will need to seperate Rc & Rh. At this point, I have to recommend a trained, qualified service technician. A good service technician should be able to resolve the wiring issue in under 30 minutes.
http://www.youtube.com/watch?v=_HyhUyU-AMI
I only wish I was able to look at exactly what you have to include tracing all the wire back to the furnace and condensing unit. Tracing the wire is the only sure-fire wire to do the job correctly.
I wish this could have been a black & white answer; however, I do hope you found this information helpful in your endeavor. Good Luck to you! :-)
Mar 10, 2010 | Ruud UBHC Air Conditioner
Major condensation comes from my gas heater
Gas heat is a moist heat. The products of combustion are condensating in your secondary heat exchanger. This is normal on a 90% or higher furnace. Open up the top of the condesate pump. You "might" just have a sickty float. If so clean it up and start adding a halve a cup of bleach a couple times a year to prevent slime build up.
Good luck......
Apr 14, 2009 | Ruud UAKA030 Air Conditioner
Ruud heat pump
Did you just install this heat pump? If so it sounds like you replace a regular a/c with a heat pump, which will require more wires for the reversing valve. First check to make sure you have 24v going to the condenser. Make sure you have a heat pump t-stat. You should have a orange t-stat wire for your reversing valve. At the t-stat you will have terminals R, Y, G, O, X or C or B, W1, and W2. R is half of your 24v circuit and is a red wire, Y is for cooling mode, G is the Fan green wire, O is for the reversing valve, orange wire, X or C or B is the other half of control circuit blue wire, W1 and W2 is the heat strips in the furnace tan and black wires. These are standard color code but remember electricity does not know colors and an installer may have used different colors. If all of this is correct possibly bad contactor.
Oct 30, 2008 | Ruud UAMB Air Conditioner
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Is ruud heat pump model upka-042jaz a single or multiple stage pump?
I NEED THE MAKE AND MODEL OF THE T-STAT TO HELP YOU
DID HE CHANGE ANY WIRING?
Jan 15, 2008 | Ruud UAKA042 Air Conditioner
RUUD Central Air/Heat Pump
Start with the simplest first it,s not fun but it's necessary EVERY TIME. Clean your evaporator and condenser coil, change your air filter. Getting to the evap. coil is often a real headache and a result doesn't get done often. When its clogged as you probably know the refrigerant can't absorb heat at the coil so it tries to absorb heat on the way to the compressor freezing the hot gas line the safety circuits that protect the heat pump compressor from getting liquid refrigerant back to the compressor almost immediately will take the compressor of line (looking somewhat like a defrost cycle). I hope this helps it's a tough repair GL!
Apr 10, 2007 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
119 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
