Question about Whirlpool LER8648P Electric Dryer
Whirlpool dryer will not start had tech check it out said it was timer replaced with new one still nothing
    New Friend:
  • 88 Answers
Check the power first, then check the thermal fuse and thermal cut off also a fuse.
Posted on Jan 08, 2009
Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
If there is no voltage on any parts ,the timer contactor is faulty
Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer not working at all
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 01, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer
NEED A NEW TIMER NOTHING YOU CAN DO ABOUT THAT
STEVE'S APPLIANCE
516-300-3249
Apr 06, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start - Whirlpool LER7646EQo
IF THE DRYER DOES NOTHING AT ALL I WOULD SAY YOUR MAIN FUSE HAS BLOWN,IT IS ON THE BLOWER BOX AND IS WHITE,YOU CAN REMOVE THE BACK PANEL AND CHECK IT WITH AN OHMS METER,IF YOU GET NO READING IT IS BAD,LET ME KNOW-MIKE
Feb 23, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer
Yes it can at times. It has been my experience. This thing may be falling apart on the inside. Just replace it before it gives you further problem. There is more heat and resistance there at the contacts. While you are replacing it, check the other things as well. It seems like you have a good eye for this anyway.
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool Dryer (Model # LER 3624JQ0) that just stopped. I push the "Push & Start" Button and get absolutely nothing. Remind you, this dryer never did turn off, I had to manually stop it each time...
Check the thermal fuse on the exit chute, white plastic. You can tape the wires together to test. If the dryer runs, replace it. Part # 3392519. Thermo next to it is also bad, part # 694674. Replace it and your timer will run down. Both parts available at www.timerking.com. Hope this helps!
Jan 14, 2009 | Whirlpool LER3624JQ Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Dec 13, 2008 | Whirlpool LER7646E Dryer
Whirlpool LER8648P Electric Dryer Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
