Question about Smart Modular SV3170A
Computer Monitor power supply is getting power but monitor will not power on
    Genius:
  • 2,985 Answers
Tried wiggling the cable and connector? Are you sure the power supply is delivering power can you rell- a meter perhaps across the connector. What voltage does the monitor work at? An alternative stabilized power supply may be a possibliity. Other wise repair shop
Posted on Jun 03, 2007
  • john ash
    john ash Jun 03, 2007
    can you tell- a meter perhaps across the connector.
    An alternative stabilized power supply may be a possibility.
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Nov 02, 2012 | Hanns.G Corporation HW191D 19" LCD Monitor
I have an Acer AL1916W monitor. After the breaker tripped to the room where the computer is located, the monitor will no come on. It's as though it has no power supply. The monitor was not the reason for...
The power supply has been compromised, if you are very lucky the fuse needs to be changed, in order to check this, remove back cover and follow the power cord to the power supply, see if you can find a blown fuse, replace to see if it will power up, if not probably more cost effective to replace monitor.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
When powering on get no input to monitor board nu a7n8x-e
Make sure you have connected into the correct video port. DVI should be used for LCD monitors and VGA should be used for CRT monitors. Since both ports look the same people often get confused. Try it and let me know.
Sai.
Jan 02, 2010 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Monitor totally blank
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
Oct 03, 2009 | HP w1907 LCD Monitor
No picture on monitor
Nothing. Power supply faults in there. Open the monitor and replace all "popped" electrolytic capacitors - they're causing the power supply get overloaded.
Sep 14, 2009 | Dell E173FP 17" LCD Monitor
Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Jun 17, 2009 | Dell E176FPC Monitor
Kogi 17 Monitor
Hi the power supply is integrated into your monitor hence you cannot buy it as aseparate component . Get it repaired by service tech guy.If you have knowledge about electronics then I can guide you to repair it.
Mar 24, 2008 | Computers & Internet
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
E17T Monitor
monitor problem any short circuit may be in secondrry side of monitor
Mar 15, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Smart Modular SV3170A Logo
48 people viewed this question
Top Smart Modular Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
