Question about Brother MFC-210C All-In-One Printer
Incorrect color I am getting too much green and magenta in an outdoor photo. It shows up on the monitor in true color, but the brown is not coming through.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My Canon MP210 never prints photos correctly! The colors come out like the right color but very incorrectly. Basically, the photos all have very severe color management problems. APparently the printer has...
Have you heard of Wysywig? What you see is what you get?
Well on color pictures on you monitor you get wysinwyg what you see is not what you get. Monitors are backlit, so colors are much more vibrant than what a printer can generally deliver. Explore the printing properties of your priinter as there are adjustments that can be made to enable better quality and true to color prints. The paper you use to print out your pics is also important in producing color that is close to original.
When you view your pics on screen try adjusting the color hue to the point it becomes overcolored and try a few experimental prints to see what level of the slide is needed to be used to achieve a brighter more vibrant picture. I would also like to say that the Canon 210 , whilst it is a very good printer, is at the cheaper end of the photo printer scale.
Talk to your ink and paper supplier, they can often show you or recommmend printers that are much higher and more accurate in delivering brighter and true to color photos.
Please rate my help++++Thanks for using FIXYA
Aug 04, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I just replaced the Yellow and the Photo Magenta cartridge in my Canon i900D printer as the computer advised. However, now my photos are coming out with green hair, lips and the other colors are not...
I would first try cleaning the print head, it is possible that print nozzles are clogged and simply not enough ink is able to make its way onto the media.
If the nozzle check page looks good I would try printing some full bleed color pages and see what it does, it is possible,but not likely, that there is either a air bubble in the ink system that could prevent ink flow. If this is true there should be a function for "priming the print head" and it should solve the problem.
Good luck.
Mar 18, 2010 | Canon Office Equipment & Supplies
All of our photos end with a magenta to purplish hue. We are using Canon inks, and followed standard trouble-shooting procedures; checked proper placement, printer alignment, deep cleaning. We are also...
Print a "test" page:
<HTML><BODY>
<FONT COLOR="#FF0000"> RED TEXT </FONT><HR>
<FONT COLOR="#00FF00"> GREEN TEXT </FONT><HR>
<FONT COLOR="#0000FF"> BLUE TEXT </FONT><HR>
<FONT COLOR="#FFFF00"> MIX RED & GREEN INK </FONT><HR>
<FONT COLOR="#FF00FF"> MIX RED & BLUE INK </FONT><HR>
<FONT COLOR="#00FFFF"> MIX GREEN & BLUE INK </FONT><HR>
</BODY>
</HTML>
and see if the printed colors are "true" to what you see on the computer-screen.
Nov 23, 2009 | Canon I960 InkJet Photo Printer
I've a canon MP610 printer and I cant get good colour prints, they are too red. Even when I try to print B/W they turn out brown. I've printer direct from the memory card and the same results. I use canon...
Do you have photo cyan or photo magenta installed? your machine does not use these inks, and will give wrong colors. You need plain magenta and plain cyan. If you are using generic inks, they could have bad colors too.
Aug 10, 2009 | Office Equipment & Supplies
My printer was printing correctly earlier in the day. I have just replaced two of the ink tanks - the others all have sufficient ink in them. I now have washed out, incorrect colours.
Make sure you didn't put photo magenta or photo cyan where the regular magenta and cyan go, the photo colors are not dark enough, and don't make the proper colors when you print.
Jul 01, 2009 | Canon I990 InkJet Photo Printer
Green hue to photos
Canon, in its infinite wisdom, markets two sets of inks with the "part" number 3e. One of these, labeled simply with the color, is suitable for the i560 printer. The newer inks, labeled as "Photo" + the color, are not. Silly me. I just looked at the number and bought the wrong stuff.
Apr 24, 2008 | Canon BubbleJet i560 InkJet Printer
Printing Problem
You may have a problem with your magenta color cartridge ????
Mar 25, 2008 | Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Primera Pro Printer
The printer will use Magenta Cyan and Yellow to produce black, if it is not printing a good black then the colour cartridge may be damaged or require a clean
Dec 11, 2007 | Primera Technology Primera BravoPro...
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
Brother MFC-210C All-In-One Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
