Question about Westinghouse 24 in. MDB421 RF Built-in Dishwasher
Replace door seal in westinghouse dishwasher.
Westinghouse dishwasher Model SB921SE*04, Serial No. 940 413 16
is leaking from the bottom left hand corner of the door.
What do I need to do to replace the seals?
    Guru:
  • 449 Answers
If the dishwasher leaks around the door, suspect a problem with the gasket. This is the rubber strip on the door that allows it to seal the water in. If the gasket appears worn, cracked, or damaged, you’ve found your problem, and the solution is to replace the gasket. Contact your dealer or the manufacturer to buy a new one. Soak the new gasket in a tub of warm, soapy water; this will make it easier to handle and install. While that’s soaking, it’s time to remove the old gasket. Before you get started, disconnect power to the dishwasher and remove the bottom rack. Just pry the gasket up with a screwdriver, undoing any screws or clips that might be holding it on. Then install the new one, starting with the top and moving to the sides and bottom, using any screws or clips that were holding the old one in place. If the gasket appears sound, the problem may be with the latch. To adjust the catch, loosen the screws holding it in place, reposition it to allow for a better latch, and then tighten the screws again. Leaks under the Door Leaks under the door can stem from a variety of causes. If your dishwasher is very old, the tub itself may have become corroded and may have holes. Inspect your tub; if you see such damage, use an epoxy patch kit to repair it, following the kit’s directions. Another possibility is that your dishwasher is not level; this can cause leakage. Open your dishwasher and place a carpenter’s level on the floor of the dishwasher or on its door. If you find that the dishwasher is not level, you may be able to fix the problem by adjusting the feet, found along the front of the dishwasher, perhaps behind a toeplate. If you have not yet found the problem, the next step is looking inside the dishwasher. Again, disconnect power to the dishwasher before getting started. Remove the front panel located below the door; this may be held on with screws or with hooks. Your goal down here is to find what is leaking so that you can either adjust or replace it. You will see a drain hose, about an inch and a half across, which connects from the dishwasher pump to the drain of your kitchen sink. At either end, it is held in place with a clamp. Check these clamps; if they are loose, use a screwdriver to tighten them. Check the hose itself for any signs of leakage; if the hose appears to be damaged and leaking, replace it. There is a second hose, the recirculation hose, also attached to the pump. Inspect the fitting and tighten if necessary, and inspect the hose itself. Check the hoses on either side of the water inlet valve to make sure that they are securely connected, and that they are not damaged. Tighten any loose clamps. The next and last items to check are the gaskets for the heating element, and the seal for the pump. If the gaskets are loose, tighten them; if they are obviously worn or damaged, replace them. If you have checked everything else, the pump seal may have deteriorated. If this is the case, contact a repair professional for replacement.
Posted on Jan 08, 2009
  • 177 Answers
Hello and welcome to FixYa!,
You need the Seal to be of a Rubber/Plastic Make.
Call up a Certified, Seal Replacer (Like 'Fridge Seal') and They will replace it for you.
Hope this helps --P3NGYJ03
    Genius:
  • 1,550 Answers
The door seal is clipped in place & the sump gasket is pressed in place.
If the door is leaking, I would recommend checking the vent plate & door hinges. You would also want to check the spray arms for proper rotation & cracks.
You need a small screwdriver or a pair of long-nosed pliers to remove the seal and place new seal .
I have a westinghouse side by side frig about 10 years old. Model number RS695V Serial number 34700050.The problem is water is leaking out of bottom of freezer door. I believe it is caused by a clogged...
The hose that goes to the water dispenser most likely has a crack in it somewhere inside the door. Usually the heat from the light in the door deteroriates the hose and lets water leak inside the door every time the dispenser is used.
Feb 19, 2015 | Westinghouse Refrigerators
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Me and my partner just bought a new house and yesterday we tried the dishwasher for the first time. I'm not sure which model we have, but it is a white Westinghouse Dishwasher with 5 wash options. The...
If the dishwasher has been setting for a long time the seals in the pump could of dryed out. Go ahead and run the dishwasher again and it could seal itself back up if not..... you will need to call a repairman to replace the seals. Or buy a new dishwasher if the unit has some age on it. You will get a new warranty..... I would also tell your realitor about it and maybe she could help you. The appliance may have a 30 warranty with the purchase of the house.......Hope this helps...
Mar 17, 2011 | Westinghouse Dishwashers
Leaking door on westinghouse tri clean dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Sep 04, 2010 | Westinghouse Dishwashers
Change door seal in westinghouse SB 907
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Jul 17, 2010 | Westinghouse 24 in. MDP531 RF...
There is a slow leak coming out the front right hand side of the dishwasher. How do I stop this?
Check the door gasket on the right hand side. See if it is damaged or not aligned properly. You may need to replace the gasket.
Sep 13, 2009 | Westinghouse Dishwashers
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
How to replce westinghouse 904 lower inner door seal
i don't think so if i remember its fairly easy open the door and take out the two screws at the bottom of the inner panel then slide the outer panel down to unhook it then take it off and you will be able to see the gasket
Feb 17, 2008 | Dishwashers
Dishwashers Logo
301 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
