Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony 36 Wega XBR Flat Screen - sudden death.
My Sony 36' XBR Wega Flat Screen is 7 years old.
While watching TV, it blanked out and will not come on again. Any help will be appreciated.
    Genius:
  • Sony Master
  • 1,689 Answers
This could be a scan amplifier failure, and there is a loss of high voltage to the CRT. Part of the power supply may have also failed. In these sets, if the CRT emission goes low in emission, or the CRT goes defective, the bias supply to the CRT will go in to protect.
An experienced TV service tech can troubleshoot the set and give you an estimate for service. Considering the age of the set, the cost of service may not be worth it.
Jerry G.
Posted on Jan 08, 2009
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Dec 13, 2010 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Sony trinitron xbr screen periodically goes black. The audio stays on but the video cuts out.
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Feb 20, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Trinitron XBR, Stand By Mode?
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
539 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
