Question about Lanzar Vibe 218 Car Audio Amplifier
Soundstorm amp hey would you be able to get specs on 1600 watt peak lanzer 12"
  • 15,935 Answers
Do you have a model #?
The MAX PRO is the only one rated @ that power.
Let me know, and Ill look it up!
Posted on Jan 08, 2009
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
WHAT TEST CRITERIA CAN I USE FOR THIS PACK
This thing is a beast! What criteria you ask? What do you want to jump? The answer.... any damn thing you want!
3200 peak amps is huge.
1600 peak amps is huge! You have got it covered here friend.
  • 3200 peak 12 Volt amps.
  • 1600 peak 24 Volt amps.
  • Integrated voltage selection switch.
  • LED battery status indicator.
  • Automatic recharging.
  • 60" Heavy-duty cables.
  • DC outlet to power a variety of 12 Volt accessories.
Sep 26, 2009 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Soundstorm amp
SPECS
  • Black P.P. Cone
  • Specially Treated Foam Edge Suspension
  • 2.5' High Temperature Dual Voice Coil
  • Magnet Weight: 95 OZ
  • 1600 Watts Max Power Handling
  • Impedance: 4 Ohm
  • Chromed Back Plate Cover
  • Rubber Magnet Boot Cover
  • Jan 08, 2009 | Lanzar OPTI1222D Car Subwoofer
    I dont know how many watzz is my amP!
    200 X 4 does mean 200 watts times 4 channels. In other words each channel pushes out 200 watts. I believe u have a total output power of 800 watts but check with ur manual and if u do use that much power make sure you check for overheating, specially if its used for bass. Soundstorm amps cant take much of a beating so be careful.
    Jan 27, 2008 | Soundstorm F200.4 Car Audio Amplifier
    Soundstorm 1600 Watt Car Amp
    Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
    Dec 14, 2007 | Soundstorm D400.2 Car Audio Amplifier
    Compatible amp for subs
    hi there. yes it should work providing you have the correct wiring it for it, if you buy the LV 416 enquire about a wiring kit to fit, most will. theyre normally around 20pounds. most amps will be compatible with most subs. i run both my 12inch 1000w off one 1200amp at half power, they kick lovely and i have no problems.
    any other quiries please ask
    adam
    Nov 10, 2007 | Legacy 2CH 1000W AMP Car Audio Amplifier
    2 12" Hitron 600w subs in a BandPass box
    Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
    Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
    Lanzar Vibe 218 Car Audio Amplifier Logo
    53 people viewed this question
    Top Lanzar Car Audio & Video Experts
    Joe Alexander
    Joe Alexander
    Chris Ward
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
