Question about Frigidaire FRT15G4B Top Freezer Refrigerator
Refrigerator tripping ground fault circuit
I have a refrigerator we are having problems with. It is a Kelvinator brand manufactured by Frigidaire located in our garage as a backup for sodas and such. Approx 7yrs old. The problem started when we moved it to our new home. I plugged it in and it runs for a day or two, then it trips the ground fault circuit at the recepticle and shuts down. It also trips what i believe to be a circuit breaker mounted inside the fridge. I have to reset the one inside the fridge by spinning it with my finger tip until i hear it "click" and then I reset the ground fault at the recepticle and it fires right up and works flawless for another day or two or even a week; Then with no warning it trips again. I checked the circuit and its a 15amp and replaced the ground fault recepticle with no luck. I also tried plugging the frige into a different ciruit and still had the problem. My thoughts are leaning to the circuit breaker inside the fridge or maybe a compressor overheating and tripping the breaker. Any ideas what might be causing this problem?? Thanks for your help.
  • johnguh Dec 31, 2008
    I have the same problem with my old GE refrigerator. One day it started to trip the GFI... I replaced the GFI and it is till tripping the circuit. Could it be the refrigerator's compressor that is going bad?
  • PjR7 Apr 22, 2009
    Frigidaire Freezer Model MFC05M3BW4, with a Manufacture Date of 6-99, is located in the garage.
    It's plugged into a GFCI. The breaker box is also in the garage.
    The freezer tripped a 15Amp breaker the other day.
    The last time was years ago. What may be the cause?
    Thank you.
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
Posted on Mar 07, 2011
  • 23 Answers
You need to plug it into a reg. outlet once for a couple days if this works then replace your gfi with a 20amp..
Posted on Jun 02, 2007
Replace lamp in Westinghouse RJ390P refrigerator
Refrigerator Repair - Replacing the Light Bulb (Frigidaire ...
? 1:39
https://www.youtube.com/watch?v=7yE0ZZBNISU
Nov 8, 2012 - Uploaded by PartSelect
Refrigerator Repair - Replacing the Light Bulb (Frigidaire Part # 5303013071) ... Kelvinator, Tappan, White ...
Refrigerator Light Bulb (part #5303013071) - How To ...
? 1:23
https://www.youtube.com/watch?v=1AQTDSn4VFw
Dec 20, 2013 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace theRefrigerator Light Bulb 5303013071 on ...
Jan 14, 2016 | Westinghouse Refrigerators
The cord for this unit got wet, and im fairly sure the fuse inside the cord tripped. It refuses to turn on.
Hello friend, thank you for your post!
I understand that the power cord to your Frigidaire air conditioner got wet and you would like to know if you can change the cord with a different brand. Even though the cords may be the same voltage it would not be recommend to interchange the cords. I would suggest contacting your manufacturer for proper replacement parts. I hope this information is helpful. -Matt
Apr 24, 2015 | Frigidaire FFRA0811Q1 8,000 BTU Window...
I bought a Kelvinator fridge in July which seems to run constantly, it has now been relegated to the garage, whats the problem? It is model No KTM 4200WB
Most refrigerators have about a 70% duty cycle, depending on ambient room temperature, content, etc. If your unit is indeed running all the time as you state, it may be low on refrigerant, have an inefficient compressor, or an air flow issue. Make sure there is no frost buildup in the freezer, the fans are running, door seals are good. If all above looks good and the temps are ok, you may just be catching it on a cycle on time and not noticing it cycling on and off, especially it being in the garage. If the temps are questionable, my money is on low refrigerant level.
Dec 29, 2010 | Refrigerators
Bad smell
clean it with baking soda hot water and hair dryer
Feb 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
2,171 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
