Question about Toshiba CX32F60 32" TV
Cannot turn close caption off
The Toshiba CS32F60 TV all of a sudden to keep close caption showing which prevents me from watching the show. Help. The TV is old but good.
  • carrie1922 Jan 08, 2009
    Did not work. Any other suggestion. Close Caption is driving me nuts.
    It says Close Caption is OFF as indicated by page 34 in the manual. Do I need to go to all the C1, C2 etc to turn off? I tried and that did not work = what color should the CC be?
  • 837 Answers
Unplug the TV for at least 5 minutes and try again
Posted on Jan 08, 2009
How do I turn on the closed captioning on my Toshiba SD 5000 DVD player
What happens when you press the "Subtitle" button on the DVD remote control several times after you insert a subtitle-enabled DVD?
If you don't have the manual handy for your DVD player, I've added a link for the Toshiba SD-5000KU. The Subtitle button is described on page 13, but the description only tells how to turn subtitles on. However if the programming is typical, pressing the button repeatedly cycles through a series of language options with "Off" at the beginning or end of the list. Otherwise, it may be programmed to enter a subtitle menu that you navigate with the direction arrows (page 14).
Toshiba SD 5000KU Owner Manual
Jul 03, 2017 | Toshiba SD-5000
I HAVE A TV, LG 37LH40 AND I CAN'T CONECT THE CLOSE CAPTION
The show u are watching must have a CC sign,before u even can get close captioning.The show's have a CC sign,tries press the button on the remote CC 1,2,3,4,5 on one of these numbers will have close captioning for the show.
Jul 12, 2010 | LG 37LH40 37 in. LCD HDTV
Closed Caption is turned on on DVD/VHS player, turned on through the TV. How do you turn the Closed Caption off on DVD
Closed captions only show when you're watching TV. If you're watching a DVD they're called subtitles. Both are controlled by a button on the remote. Closed captions are controlled by a button that's labeled "cc" or "ccd". Subtitles are controlled by a button that is labeled "subtitles" or "sub". Subtitles can also be turned off by going into the DVD setup menu.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Jan 10, 2010 | JVC Televison & Video
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
