Question about HP Pavilion dv2500t Notebook
Computer HI. My cd-rw/dvd-rom Combo Drive has A Problem.The Problem It Won't red the drive .I put A Dc in the Drive It Won't bring It Up why.Could you tell Me How To fix It. My computer is not reading any cd's or DVD's. How do I fix this problem. My computer did not come with any driver disks. Thank you.
  • 2 more comments
  • Super Mom2 Jan 08, 2009
    IThank you. Where do you get a cleaning disk? Also, it doesn't reconize any disk that is inserted, like the driver isn't there. So I doubt it will load a cleaning disk. Any other suggestions?
    Great. I will try this!
  • Super Mom2 Jan 09, 2009
    I needed to contact HP and they had me uninstall the driver and reinstall it. I will keep it clean though thanks to your advice!
    Cheers.
  • edeg86 Feb 13, 2009
    i ahve exactly the same probably i uninstalled its driver but now i cant find the driver for the cd-rom on the internet help please?
  • 837 Answers
Try a cleaning disc ...
Posted on Jan 08, 2009
  • 1 more comment
  • Jay Glendenning
    Jay Glendenning Jan 08, 2009
    They are available just about anywhere you can buy CD DVD discs
    If the eye is dirty .. that is a possible "response" .. not recognizing a disc being inserted
  • Jay Glendenning
    Jay Glendenning Jan 09, 2009
    What happened after the cleaning?
  • Jay Glendenning
    That would have been the next step .. but as a "tech" and when someone says its not working/reading .. we try to make sure that we eliminate "environmental"issues.
    Thanks for the rating ... Hope to be of help to you again .. if you ever need it ..
    Crayz
I have a hp dv9700 and my cd player will not read Missing from My Computer DVD Rom (E)
Check the cables, either DC supply to CD Drive or Data cable from CD Drive to Mainboard (Sata or Pata connection)
Aug 11, 2010 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Combo drive reads cd but not dvd
Hi ,it could be that your dvd is dirty,scratched or corrupted.Try your dvd in another computer to see if it is ok .If you use Nero Burning Rom go to your Start menu.a All Programs ,Nero.In the sub menu Click on Nero Tools and select Nero Info Tools and see what that brings up.Hope this helps you.
Regards Bill
May 26, 2010 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Apr 09, 2009 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computer
HI.
Oct 12, 2007 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
HP Pavilion dv2500t Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
