Question about Epson Stylus CX7800 Color Flatbed All-in-One Printer
Color priting problem
Pictures turn out mostly green
  • randy_tammy Feb 17, 2009
    all pics have a greeen tint to them
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
After turning the tv on the colors are reddish and slow to conform to the normal color tones. i have a 36" toshiba flat screen tv
My first concern would be that, the picture tube is going bad. The problem you describe, tell me one of the color guns is shorting. In this case I would think the green gun is shorting. There are three color guns in the neck of the picture tube. They are red, green, and blue. Most of the time the green will short as it is powered heavily in most TVs. The next thing to check, is the small board connected to the picture tube. Look for any and all bad grounds on this CRT board. This is another big problem in all Tube type TVs. On this small board there will be three color output transistors, and resistors. These will many times run very hot and will create bad grounds over time. Check and resolder as necessary. If the CRT board does not fix your problem, replace the TV. Picture tubes are very expensive and will not be feasible for replacement. Search for a new TV. Thanks for asking and show all hands of support!
Jun 26, 2011 | Toshiba 36A43 36" TV
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
The color is fading. i almost can't see the picture at all. Everything is turning green
you should really see an electronic technician , your problem is not that bad , just electronic parts getting loose ( must re-apply solder to them ) and this will solve you problem , some calibration have to be done also !!
Mar 10, 2010 | Akai Audio Players & Recorders
Problem with rca hd52w58 52" tv
This can be a green crt or green driver pcb problem. You can try and unplug the tv for 30 min. and plug it back in and turn it on, but the problem will most likly still be there. A repair shop will need to fix it from there.
Oct 22, 2008 | RCA HD52W58 52" TV
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Black does not print well
Try priting a test page to identify the color in questions.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Chances are you are running out of another color...
In reality the printers actually use other colors to print black, besides the black ink. (I.E. if its a picture etc...)
A greenish hue normally means your Magenta is running low.
http://en.wikipedia.org/wiki/CMYK_color_model
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Color of picture
turn off the color completely and see it the picture is black and white or has a shade of green,if so your gayscale needs to be adjusted
Sep 09, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Epson Stylus CX7800 Color Flatbed All-in-One Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
